Old 02-25-2007, 09:45 AM
wlmrfair wlmrfair is offline
99 Voyager 3.3
99 3.3 Voyager. Starter seems as though the silenoid would not engage. I took it off the car and had it checked at AZ. Checked ok. Checked three times total and came back good each time. Checked the flywheel, no teeth missing, put starter back on and installed new battery. Same problem, starter spins without a doubt but it does not engage. This came out of the blue. Any ideas of what to check next?!?
Old 02-25-2007, 10:14 AM
KManiac's Avatar
KManiac KManiac is offline
Re: 99 Voyager 3.3
The drive gear on the starter is equipped with a one-way clutch that provides positive engagement when the starter turns the flywheel, but allows the gear to freewheel when flywheel speed exceeds starter drive speed upon start up. Sounds to me like this one-way clutch has failed and the drive gear is freewheeling in both directions. I have heard of this one-way drive gear referred to and the "Bendix Gear". To verify, you will need to remove the starter and try spinning the drive gear both directions. If the gear clutch is functioning properly, you should be able to turn the armature in only one direction. If you cannot turn the armature by spinning this gear in either direction, the clutch has failed. You can either replace the drive gear yourself, or just buy a new or reman' starter. Either way, let us know what you find.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 02-25-2007, 12:33 PM
imamacanac imamacanac is offline
Send a message via MSN to imamacanac
Re: 99 Voyager 3.3
You may also want to check the flex-plate ring gear. I had a flex plate crack all around the bolts that mount it to the torque convertor. And it would only spin the flex-plate when you tried to start it. Good Luck!
