Old 02-25-2007, 03:06 AM
PlayStation3 PlayStation3 is offline
Freinds problem
ok, so a person at works system is acting up. when you turn the volume up more then 10 (out of 62) the amp goes into protection mode. i told him to clean up his connections( it was a mess 2 inchs of exposed wire with tape cover it and stuff like that). and he did and it helped for a little bit then it started up again. it thinks that he is having a grounding problem with the car. now it does sound like a power/ground problem but how would i be able to fix that.
what i was thinking was running a cable from the negative terminal and attach it somewhere like in the corner of rear corner of the car and attach the amp ground near it so that then it should be getting that. but i'm not totaly sure if i get what grounded means in a car.
Old 02-25-2007, 09:35 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Freinds problem
the cars chassis is the negative wire. It sounds like the gains are set wrong.
Old 02-25-2007, 12:21 PM
Re: Freinds problem
alright thanks i will look into that. i assumed that it was set right. btw was i right about how grounding works in a car
Old 02-25-2007, 03:04 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: Freinds problem
I couldn't really understand what you were saying about the grounding but it sounds wrong.
To ground your amp run the shortest wire you can from the ground on the amp to the chassis.
Like Paul said sounds like gains are set wrong or the amp is seeing to low of an ohm load.
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 02-25-2007, 06:03 PM
Audio Guy
Re: Freinds problem
I didn't even think about impedance loads .... what amp and how are the speakers connected ?
Old 02-25-2007, 09:02 PM
Re: Freinds problem
3 svc 4 ohm subs. it looked series
Old 02-25-2007, 11:05 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: Freinds problem
Why would he run it in 12ohms. Maybe series/parellel. I had a friends amp tht did it. ended up being a blown sub.
But check the wiring, it could also have a little extra wire exposed and when it hits that wire might be hitting the other lead to the sub or the subs chassis.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 02-26-2007, 10:42 AM
Re: Freinds problem
it might be a blown sub i will try all this next time i see him which i think will be tomorrow. oh and he would wire it in 12 ohms because he knows nothing about audio period and makes no attempt to learn.
Old 03-03-2007, 10:25 PM
dbfreak147.5 dbfreak147.5 is offline
Re: Freinds problem
that is incorrect 3 svc 4 ohm subs make an ohm load of 1.34 and your friends amp probably doesn't hold stable below 2 ohm so wire two subs in series to one channel and wire the other one normal to the other channel
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 03-03-2007, 10:46 PM
Re: Freinds problem
actuly you are worng series all you do is add up all the subs ohm load. and it was series paraelle and it is not his amp we disconnected his amp and moved it to my car and and we disconnected my amp and we hooked up my rca and remote and power/ground but with his subs and we got it to work. so i told him to go buy a new amp kit and rewire his stuff.
Old 03-03-2007, 11:55 PM
Re: Freinds problem
Thank you playstation. And dbfreak wiring seperate channels to different impendances isnt a good idea. What brand subs. Jw wondering cause theres a MTX setup that is prewired for 4 ohm.
Cardomain
Old 03-04-2007, 12:05 AM
Re: Freinds problem
thank you pimprolla for telling me that
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
