awesome.
Re: awesome.
What exactly did you do? I know you are supposed to switch from high beams to fogs...or use your fogs period.
![]() 05 Srt4 Agp 3147 w/supporting mods ![]() 97 Mx-5 T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box, |
Re: awesome.
i wasn't trying to do anything,well,aside from see at night.
the multifunction switch went and melted the connector,i'm lucky my car didn't burn up. all electrical is bone stock to the the bulbs, no modifications. check your switch when you get a chance, chrysler doesn't sell just the connector,if i want to fix this properly,i have to buy the entire dash wiring harness, $700. |
Re: awesome.
apparently this is a fairly common problem,i'm astounded that chrysler hasn't issued a tsb for this.
Re: awesome.
You don't need the whole harness. I will email you a solution.
Re: awesome.
opcorn:
ThE neW wHiP:
Re: awesome.
its a known problem
Re: awesome.
i use my foglights all the time.... please explain wut happened?
Re: awesome.
Dodge uses too thin of wiring and what will happen is it will overload the connection on the multifunction switch. It will burn up your clip and usually your switch itself. I recommend not using your fogs, brights, or switch from fogs to brights. Those seem to be where some of the trouble starts. Also, if you purchase aftermarket HID's, be sure to use a relay harness because the initial turn on is enough to overload the wires.
Re: awesome.
damn man thanks for the heads up...i used to use my fogs all the time
no more fogs or highs
ThE neW wHiP:
Re: awesome.
Re: awesome.
yea...i would if i knew how lol
im not so good with electrical work
ThE neW wHiP:
Re: awesome.
It's not very difficult, I just ordered my harness from element motorsports...and I plan on not using my headlights until it gets here....to prevent from any unwanted melting from happening. Basically it's a plug-n-play type deal. One wire goes to the left side of the harness, one wire goes to the right side of the harness, one to the ground, and one to the positive on the battery. All this prevents any power going through the harness itself and straight from the battery instead. If you get any new bulbs, hids, or use your fogs a lot...this is definitely something to look foward to. Element sells the harness for $50...and trust me...it's definitely worth the money. Think, you will be spending $50 either way...on a new clip or on a relay harness. Why not make it easy on yourself and avoid the pain of having to splice all those wires...trust me...the dealer will not warrenty this.
Re: awesome.
This is interesting. I just went and looked at a black '04 today and I came here looking for things like this. Are there many things like this that commonly go wrong with these cars? I'm a Nissan man so, as bad as this may be, buying a Dodge kinda creeps me out. I really like the cars but I'm wary...I wonder if I really should be like this. Any info is appreciated, guys! Thanks!
Who cares what's in your wallet...what's in your garage? ![]() VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31 Hope you can see the tiny pic...AF reduced the size limit! Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Re: awesome.
04's tend to be the best year to purchase. It can easily be remedied with a relay harness. I wouldn't let something like this scare you from going through with it. Just check your basic stuff and you should be fine.
