Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-24-2007, 01:23 PM
josecho josecho is offline
95 T- Bird IAC Valve
I would appreciate someone telling me where the IAC valve is located in a 95 4.6 T- Bird.I understand that it is located on the intake manifold,but specifically where? Thanks
Old 02-25-2007, 08:14 PM
Garbagemann55 Garbagemann55 is offline
Re: 95 T- Bird IAC Valve
On the right of the throttle body. 2 Screws, be careful NOT TO STRIP THEM!!
1996 White Isuzu Rodeo 5-SPD
Old 12-01-2007, 05:35 AM
reino134 reino134 is offline
Send a message via AIM to reino134 Send a message via MSN to reino134 Send a message via Yahoo to reino134
the tps (throttle position sensor) is located on the drivers side of the throttle body mounted with 2 phillips head screws. The IAC (idle air control valve) is located on the same side, but back near the firewall. You will have to look down at the rear of the motor and you will see it. it is mounted with 2 bolts, and dont forget the gasket....
i am just correcting the info on this older post for others future reference
