Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-23-2007, 04:02 PM
amm22camaro98 amm22camaro98 is offline
'98 V6 camaro rebuild
I would appreciate any help I can get on rebuilding my V6 camaro. It's a 1998 and I'm looking to put an SLP loudmouth exhaust kit on already but as far as upping the HP, what should I do?? I would like to get 375 or 400 out of it but i'm not sure where to start. I'd like to avoid buying a supercharger. Basically, I need somebody to tell me all the parts i'm going to need to buy! Thanks
Old 02-24-2007, 08:46 AM
Engine Rebuild / How do I go faster?
I have a 1998 V6 Camaro and I was wondering how to make it faster without buying a supercharger. Where do I start??
Old 02-24-2007, 01:11 PM
stieh2000's Avatar
stieh2000 stieh2000 is offline
Re: Engine Rebuild / How do I go faster?
Naturally Aspired 3800 making 375+hp, good luck
Maybe if you bore and stoke it close to 5L, add a HUGE solid roller cam and spin it to 8000rpms.
But stock cubes with a big cam and nitrous should be doable.
Apperance Mods: Firebird wheels of mysterious origin , Floormats , and a quarter sized dent behind the passenger door from a TV I dropped!
Old 02-25-2007, 12:51 AM
Morley Morley is offline
Start by adding 2 more cylinders. You could latch onto an LT1 cheaper than a supercharger. The only real problem would be the wiring, but if you have the time and can read wiring diagrams it would prove worthwhile.
Old 02-25-2007, 05:53 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
suck a LOT of bottle
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 02-27-2007, 02:36 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
the only way to hit 375-400hp in that engine is forced induction (turbo/supercharger) or nitrous. with either option you'll probably want to use forged pistons, considering how much boost (or juice) you would be putting to it.
if you really want to do it with that engine, i would use 2-stage nitrous (or a graduated system where the controller gradually applies more nitrous til the max), forged pistons, a better cam, and a shift kit.
this is a relatively easy setup if you are rebuilding it yourself. you're still looking at about $2000.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
