Go Back   Automotive Forums .com Car Chat > Opel/Vauxhall > Commodore/VS/VT/VX
Old 02-24-2007, 01:46 AM   #1
jjfur
Car Stalling
My Car is stalling at random times, both when driving and when idle at lights etc. When it stalls it the drive train, battery and oil lights all come on. I've checked the oil and the battery but nothing seems wrong with them. Does anyone has any idea what is going on?
jjfur is offline   Reply With Quote
Old 03-02-2007, 04:12 AM   #2
mmcleo11
mmcleo11's Avatar
Re: Car Stalling
When it stalls, you loose oil pressure and voltage, hence why these lights come on. It is normal and is also why they should come one, when the ignition key is in the ON position before you start the car.
What sort of car is it? V6 Commodores are common for having the harmonic balancer rubber fail and put the ignition timing out, which causes the car to stall. The harmonic balancer is at the bottom of your fan belt, which is the big pulley your crankshaft turns.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
mmcleo11 is offline   Reply With Quote
Old 03-04-2007, 10:24 PM   #3
EvilSpeed
Re: Car Stalling
I agree with the harmonic balancer thing, that bugger is always an issue on VR, also check the plug on the alternator give it a wiggle with the engine running, if the rev sound changes it could be as simple as getting a new plug and not a whole new alternator as I found out the hard way.
EvilSpeed is offline   Reply With Quote
Old 03-30-2007, 04:06 AM   #4
sparkeykev
Send a message via Skype™ to sparkeykev
Re: Car Stalling
what make model and year is the car vl comadore had probs with the plug at the airflow meter boot perishes water gets in and corrodes terminals
sparkeykev is offline   Reply With Quote
Old 03-31-2007, 07:49 AM   #5
jjfur
Re: Car Stalling
It's a 1997 vt acclaim. One of my mates has suggested that it could be the idle speed, is this likely to be the problem?
Old 04-04-2007, 04:33 AM   #6
mmcleo11
mmcleo11's Avatar
Re: Car Stalling
VL Commodores also have problems with the Crank Angle Sensor in the Distributor, water getting into the Crank Angle Sensor boot, Air Flow Meter failures, Fuel pump failure and then a number of other VL related problems that mechanics refer to as 'VL-itus'
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
Old 09-24-2007, 05:09 PM   #7
Club327
Re: Car Stalling
the idle air control valves are known to stick, causing intermittent stalling. The IAC valve should be replaced if suspect - the valve's located on the throttle body. The crank angle sensors when they're faulty, cause the engines to stop and not restart until the sensor cools down. Throwing water onto a hot sensor will usually get the car to restart if the sensor's at fault.
Club327 is offline   Reply With Quote
