Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-24-2007, 12:42 AM
takae86trueno takae86trueno is offline
need help on rev limter not speed limiter??????????
i recently bought a 1995 240sx se and for some reason i can rev higher than 5200rpm. It limits me there but my rpm gauge says that it redlines at 6.9 why cant i go past 5200rpms. My car is completley stock so can someone plz help me out.
Old 02-24-2007, 03:28 PM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: need help on rev limter not speed limiter??????????
what gear is it limiting you at 5200rpm, i hope your not talking about 5th gear.
If anything else check your ecu codes, you might be running in safe mode which takes the rev limiter down.
try reseting the ecu codes and go from there.
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 02-24-2007, 03:42 PM
slideways...'s Avatar
slideways... slideways... is offline
ill wait for an answer before i chime in
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 02-24-2007, 10:27 PM
__s14__ __s14__ is offline
how do u do that...im a newbie
Old 02-25-2007, 01:21 AM
http://www.240sx.org/faq/index.html
look up ecu resetting and you might want to check your ecu for codes...look up ecu codes (dohc or sohc, depending on your motor)
Current cars:
