Old 02-24-2007, 12:32 AM
DSM Monster DSM Monster is offline
Mounting a BOV
so i havent been able to find any one who sells just a piece of piping that i can mount my bov to. i found whole upper intercooler piping kits but their alittle out of my price range at the moment. so any help on this matter would be great.
Old 02-24-2007, 11:02 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Mounting a BOV
you can either get a flange that has to be welded onto the IC pipe. but if you have the stock rubber/plastic IC hoses, then you may have to opt for one of the DSM BOVs with adapter. OR, if your BOV doesn't require a flange mount, you can simply use a small section of rubber radiator hose and attach both ends with hose clamps.
1st gen DSM BOV with ADAPTER. adapter is on the back.
IC pipe section with BOV adapter welded on.
3SX.com sells a bunch of BOV mounting kits here.
Greddy type-s BOV adapter
HKS weld-on adapter flange
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-24-2007, 08:45 PM
Re: Mounting a BOV
okay thanks i think im just gonna have to get a piece of pipe and weld it one cuz i have a greddy bov that i have been waiting to put on.
Old 02-25-2007, 01:39 AM
Igovert500's Avatar
blue + red light magnet
Re: Mounting a BOV
What exactly are you looking for? My greddy fit w/ the stock piping fine. It was in the way of the shifter counter-weight though. So I had to relocate it. If that is what you are talking about...I went to Autozone and asked to look at their radiator piping. I took my BOV there, found a pipe that fit, took it home, cut it down to size, done deal. Is that what you are talking about?
Because I'm 90% sure my Greddy came with the adapter.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-25-2007, 10:00 AM
Re: Mounting a BOV
mine didnt come with the adaptor... ebay. but maybe ill just get an adapter and do what you did. it sounds pretty painless. so let me see if i got this right. just get rad hose from bov to where the stock bov? do you got any pictures to make this project alittle easier
Old 02-25-2007, 05:57 PM
Igovert500's Avatar
Re: Mounting a BOV
No pics...sorry. I don't have a digital camera.
Well I'd try mounting it in the stock location seen here
Shift through all hte gears...see if you can get into them all or if you are getting blocked. If memory serves me right, I couldn't get into 1st, 3rd, or 5th. If that is the case, what I did was get a straight radiator hose that fit the BOV, that is about a foot long. I also got a radiator hose repair kit. Which is basically a plastic hollow tube the size of a D battery, and 2 hose clamps.
NOw look at this pic.
I jammed the plastic tube from the radiator repair kit into the bottom of the intake 'bubble' that is labeled 'feedback outlet' in the picture. I then took the hose labeled 'hose to y-pipe' and disconnected it from the y-pipe. Then I attached it to the other end of the plastic radiator repair plastic piece. Then I attached the Greddy BOV feeback end to it. This hose has a curvature to it, so I pointed it away from the tranny. Kinda like up and towards the battery.
Then I used the radiator pipe that I had just bought (and thouroughly cleaned) and connected one end of it to the y-pipe and one end to the BOV inlet. Clamp everythign down so it doesn't blow off.
At this point, my BOV was basically between where my intake box would be, and my battery...but lower to the ground. It points kinda downward which was a PITA for adjusting. But once I got it adjusted to where I wanted it..I havn't had to touch it.
http://www.supercar-engineering.com/...BPV/index.html
^This site shows installation and just zip ties it outta hte way. Which probably works. But I prefer mine. Personally I'd rather not lose half my gears some day while cruising if a zip tie or 2 break.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-25-2007, 07:28 PM
Re: Mounting a BOV
awesome description thanks for all the help. i just have one more question. in eclipses if u dont recirculate the bov it will mess with idle... do vr4 / tt have this problem or can we run open?
Old 02-25-2007, 07:34 PM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
Re: Mounting a BOV
You want to recirc it.
Old 02-26-2007, 03:44 PM
Igovert500's Avatar
Re: Mounting a BOV
Yeah we have the same problem...because the air is already metered by the MAS. You wanna recirc it, as Stealthee said, or you may run into rich situations and stalling problems
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
