Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-23-2007, 10:01 PM
torlok2002's Avatar
torlok2002 torlok2002 is offline
Drum Brakes - Cannot remove rotor
Well, it's time to replace the rear shoes and I cannot seem to get the drums off for the life of me. I know there are threaded holes that I can thread a screw through, but I don't have the screws. On the front wheels there is what appears to be a little threaded piece welded to the disc shield that appears it would serve the purpose of holding a screw for this application.
The only problem... There are no screws in them. I have checked both front wheels.
Would anyone know how I could obtain this screw, or what the dimensions are, and could I pick one up from Autozone or similar store?
Old 02-23-2007, 10:33 PM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Drum Brakes - Cannot remove rotor
It's actually for a puller. Autozone rents them I think. You clamp around the back of the drum with them then as you turn in the screws it tightesns the clamps and pulls the drum free.
Thats how it worked on my Cavalier anyway. I never had to do rears when I had my spyder gs.
Note be sure to clean it up because even with the puller it can get to be a pain to remove if it's all caked on.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 02-23-2007, 11:41 PM
torlok2002's Avatar
Even the repair manual says that I just need the screws. The holes are threaded, and as the screw pushes through it hits the hub(wheel assembly.. or whataver its called) and forces the rotor off. Forgot to mention there are 2 of them on each side of the rotor.
Old 02-24-2007, 12:26 AM
nova1313's Avatar
try autozone they most likely rent/lend them out. If you have the thread size you could always check out a local hardware store. The pullers are just the screws with clamps on the side. It works the same way.
I use pullers because thats what we own. But it's the same idea screws in and then pops drum off.
Old 02-24-2007, 08:50 AM
torlok2002's Avatar
Well, then I guess my question is does anyone know the thread size, or how to obtain it? This is a 98 RS.
Old 02-24-2007, 10:07 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
One thing I learned it to just whack it with a sledgehammer or something of that matter towards the bottom of the drum that faces outwards (the flat side). Its probally just stuck on there from brake dust or what not, but giving it a good whack has always worked for me.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 02-25-2007, 09:41 AM
torlok2002's Avatar
Well, I've got a decent sized rubber mallet I've been taking some cracks at it. If I put any more force into it I'm afraid I might bend/warp the drum. The drum has some nice corrosion holding it on, I can see that, but just can't get it to budge.
Nice looking RS btw. What kinda wheels are those?
Old 02-25-2007, 03:04 PM
Turbo makes me emo!
Believe me man, don't be afraid to take a sledgehammer too it. When I went to UTI, my instructor whacked the shit out of mine and I was like "damn!". I mean don't take a full swing ofcourse, but a firm hit shouldn't hurt it at all, the drum is pretty stout. This is going to be a very obvious question, but you do have the e-brake disengaged when you're trying to take the drum off right? Just wondering because I've done that before, felt a bit retarded when I realized the e-brake was on, lol.
And thanks for the compliment, the wheels are off a 300ZX believe it or not.
Old 02-25-2007, 07:03 PM
torlok2002's Avatar
Indeed the brake is off. ;-)
I'll give it another go with the hammer tonight when I get off of work and see how that goes.
Old 02-25-2007, 08:47 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I did some rear brakes for a friend on a 99 Grand Am and holy damn, I had to hit the fuckin thing probably 50 times before it finally came off, so don't be afraid to use some force.
95 Talon TSI AWD
97 Eclipse GST
Old 02-26-2007, 07:27 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I know this sounds dumb, buy you don't have the e-brake on do you?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-26-2007, 05:20 PM
Xevenskyline already asked that.
95 Talon TSI AWD
97 Eclipse GST
Old 02-27-2007, 07:28 AM
Ah, I missed that......I guess I should stop skimming replies.
1997 Spyder GS-T
5-Speed
Old 02-27-2007, 08:42 PM
torlok2002's Avatar
Smile Re: Drum Brakes - Cannot remove rotor
Well, I went apeshit on the drum and it finally broke free. I didnt have a sledge so I kept hitting one side with the rubber malet and alternate the other side with a large claw hammer. Finally broke free after a couple of minutes of this.
After the auto parts store trying to sell me 2 different pairs of rotors that would not of worked I went somewhere else and got the right pair. Everything is back in it's right place and working like a champ.
Thanks all!
Old 02-27-2007, 09:26 PM
Turbo makes me emo!
Invest in one of those sledgehammers with the yellow, plastic/flexible handle. That thing has come in handy for me on numerous occasions.
