Old 02-23-2007, 08:17 PM
Steven M Steven M is offline
Blower motor clicking noise
When I first start my 96 there is a clicking noise under the dash glovebox. It does not seem to be the fan motor, seems more of a vacuum actuator slipping or something. Only lasts for 10-15 seconds. Anyone have a fix for this?
Old 02-23-2007, 08:25 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Blower motor clicking noise
If you're convinced it's not the blower fan then try this:
"Start the van and turn on the blower. Simultaniously push the top and bottom wiper buttons on the left side of the ventilation control panel for 5 seconds. All the lights on the panel will light up. Then two lights on the left side will alternately flash for about two minutes and you'll hear the ventilation modes cycle. When just the top light on the left side slowly flashes push that button and you're done. All lights should be out and you should be back to normal. Restart the van a few times and make sure. This is the ventilation control calibration test and it resets the ventilation system computer."
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-27-2007, 11:43 AM
dcx96 dcx96 is offline
just change your ac filter under the glove box that should do it. let me know what happens please.
Old 02-28-2007, 07:33 PM
Sorry so long to reply. Found noise to be a motor/gearbox mounted under glovebox duct work. It has some teeth stripped off a gear. This thing changes position of a door inside. I think its the door for the recirculation. Have not figured out how it exactly works yet, but does need to be replaced. RIP thanks for the vac. proceedure, thats really slick.
Old 03-01-2007, 02:01 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Your best bet will probably be a junkyard. The dealer will probably tell you you have to buy half the car to get the part. By all means though give them a try. Let us know how you make out. Cheers.
