Go Back   Automotive Forums Car Chat > Cadillac > Catera
Old 02-23-2007, 06:31 PM
tgentis tgentis is offline
'98 Catera Battery Drain
This Catera will not restart after being left overnight, charging system checks out good, battery load test shows good battery. Test light between battery terminal and positive cable end (removed) lights up and doesn't go out until you pull almost every large fuse link out of the box. I'm sure this vehicle is supposed to have nominal draw from the battery in key out engine off status, but I think it should only light the test light dimly, not so bright.
Any input would be greatly appreciated.
tgentis, Anchorage, Alaska
Old 02-24-2007, 11:45 AM
DFBonnett DFBonnett is offline
Re: '98 Catera Battery Drain
Try disconnecting the alternator overnight and see if that changes anything. I'm thinking about a bad diode.
Old 02-24-2007, 12:04 PM
Thank you for your input. I shall try this... the alternator on this vehicle is difficult to get to, but I will do as you suggest.
Thank you again... any other input still requested.
tgentis
