Old 02-23-2007, 04:13 PM
chevyguy93 chevyguy93 is offline
Question surging idle and stalling
Okay so i've had this problem for a very long time now, and i really want to try and get it fixed before summertime. I have another post floating around from months ago, but ive decided to start a new one.
Problem: After driving around 10 minutes (time sometimes varys, and it does not always happen), the idle seems to surge (dropping and then raising) continuiously while sitting still. If i leave the gas alone and let it surge, it will eventually drop almost to where it stops, and then it starts back up again and the idle raises permanently to stop the car from stalling. But then its harder to brake, and its hard on the transmission. The odd time, it will stall when on a downward slant. And once, i pulled into a parking lot, and the call stalled just before i went to put it into park. And after an hour when i left, i started it up, and as I put it into drive, it stalled. I really had to give it gas to get it going.
Sometimes when im driving and i go to slow down to a stop, the car shakes as it shifts down through the gears.
What I've replaced: spark plugs, wires, TPS, IAC(cleaned and even replaced with another), egr valve, the valve thats ontop of the valve cover in that tube (i forgot the name), o2 sensor, air filter, and the fuel filter had been replaced last summer.
I was told it may be water in the tank, but ive had the problem for many months now, and with each fill-up i've been adding premium water absorber/gas antifreeze to it to get rid of any water that may be in there, but it hasnt been doing anything.
ANY ideas? lol. I went out and bought another fuel filter, and when i get some time I will replace it again.
2003 Grand Prix GT
1993 Cavalier 2.2L
Old 02-23-2007, 09:35 PM
Dead_Sunfire Dead_Sunfire is offline
Re: surging idle and stalling
Hi Chevy Guy ...
I have EXACTLY (right down to last detail) the same problem with my 2003 Sunfire 2.2L.
My car starts perfectly, idles perfectly, and runs great for about 20 minutes, and then when I go to stop at a stop sign, or slow down entering a parking lot, the RPM drops to about 500, and car stalls. No shuddering or thumping or anything, just stalls.
When I try to start again, I really have to give it gas, but it always starts right up again. Then when I keep driving and take foot off gas, the RPM drops down to 500, I give it gas, and then surges to about 1500 and stays there until I put foot on brake, then it tries to stall again.
But if I shut engine off, and let it sit for about 20 minutes, the problem goes away for another 20 minutes, then it starts acting up again.
At first I thought it was the cold weather. We have been having -20 cold lately, but a few days ago it was quite mild, and it is still doing it.
So far I've put in new battery (was getting old anyways) and new fuel pump (about 6 months ago). Thried the premium gas thing with gas line antifreeze to no avail.
I can still drive to work and back everyday without a problem, but I'll never be able to leave town again until I get problem fixed.
Hope you find problem soon. Let me know how you make out.
Bob
Old 02-23-2007, 10:00 PM
4caster 4caster is offline
I am not familiar with the 2.2L engine, but I had identical symptoms from an '89 2.5L engine. The problem was caused by a leaking vacuum hose on the emissions system. The problem would kick in once the engine warmed up. As long as I was driving, the engine ran fine, but it would surge and stall at idle.
Good luck!
Old 02-23-2007, 10:34 PM
spudracer73's Avatar
spudracer73 spudracer73 is offline
guys check it. he above is right about the vaccum leak. do this man it works. Get a propane torch. DO NOT LIGHT IT! just had to make that clear. turn the gas on a little and run the torch tip around the intake and anywhere you suspect a vaccum leak. the engine should speed up and smooth out when the gas gets sucked in. i have done this shit so much with vaccum leaks and it works every time. try it!
AAS in Automotive Technology, and never stop learning!
Old 02-23-2007, 11:47 PM
okay well. i've looked before for vacuum leaks, by unplugging certain lines and listening for a change, etc. but i couldnt find anything. But its worth another look i suppose. And yea, this isnt a fun problem. I can get to work and home fine, but i cant go downtown to the mall or shopping anywhere because it will just stall.
2003 Grand Prix GT
1993 Cavalier 2.2L
Old 02-24-2007, 05:57 AM
I'll try it too this afternoon (the propane thing) and let you know if any luck.
A few other clues.
a) It's interesting to note happening on both a 90's Cavalier and a 2003 Sunfire - must be something common to both models
b) The check engine light never comes on, so the engine must think everything is o.k.. That rules out problems that would normally make the light come on.
c) I've been searching other forums and groups for weeks on end. I've found similar threads discussing similar problems, but none so exact as Chevyguy93. Interesting to note that we are both in Canada, with approx. the same recent weather conditions. Very cold. This might indicate something temperature related or possibly even a US vs. Canada emmision control standard difference.
BP
Old 02-24-2007, 08:22 AM
Just went to Walmart to pick some stuff up for wife, and found OBD2 readers on sale, so I bought one.
It shows a code P0172 fuel mixture too rich error.
Old 02-24-2007, 10:28 AM
muff34 muff34 is offline
I read somewhere before on the AF where a Coolant sensor goes bad and the puter senses cold condition and as a result engine gets too much fuel . On the `03 it is located in the coolant pipe ,at the right front corner of the cylinder head,near the alternator. Hope this helps.
Life Is A Highway ,Enjoy The Ride
Old 02-24-2007, 10:53 AM
chevy guy if you are curious about this ,look for sensors at thermostat housing. there may be two of them . the one you want will have a yellow and black wire . DO NOT GROUND it or computer damage may occur. Good luck in whatever you do here. let us know if you figure it out. I like the propane trick........if I can just remember it ...........lol
Old 02-25-2007, 01:38 AM
thanks muff34! i'll definately look into that. I didnt even think of that. I know that a while ago i was having some problems with the temperature going into the red and then dropping. but i didnt think that it would be related.
2003 Grand Prix GT
1993 Cavalier 2.2L
Old 02-25-2007, 08:18 AM
I feel like a real dummy now. My last car actually had an engine in it (i.e. you could find a distributor, spark plug wires, carb etc.) This 2.2L seems to be nothing more than a block of metal with a million sensors on it ! It was easy to do the propane trick, considering I could only find 2 vacuum lines on te whole dang thing !
Hee hee ...
Anyways, the upper rad hose dissapears into what us old guys would call the rocker cover. Is it safe to assume that the thermostat is under this cover, and that by removing the cover, the thermostat and sensors will be exposed ?
Old 02-25-2007, 01:04 PM
On my`00 2.2ohv the ECT sensor is in the coolant pipe that runs across the front of engine ,if I look at the alt it is in behind serpintine belt. If yours is a 2.2ohc it`s located on thermo housing located on left rear corner of the cylinder head.
Old 02-25-2007, 01:08 PM
Sounds like you are confusing this sensor with temperature sending unit now. The ECT feeds info to the PCM as to how warm engine is .The PCM will then control air/fuel mixture along with other things
Old 03-01-2007, 11:01 AM
the problem seems to have gone away for some strange reason, but I havent been going for long trips. I'll post when it comes back.
2003 Grand Prix GT
1993 Cavalier 2.2L
Old 03-01-2007, 03:02 PM
Me too, but it's been milder, and I havn't driven for any more than 10KM at a time. Going to take longer trip this weekend.
By the way. When you are coasting to a stop, does it feel like the transmission is still slightly engaged ? I did't notice as much when colder and snow on road, but now that road is bare pavement, it seems like the car is still trying to creep when foot is on brake.
Starting to think maybe problem is transmission related. Still no engine codes on OBDii monitor.
BP, Ontario
