Go Back   Automotive Forums Car Chat > Ford > Probe
Old 02-23-2007, 03:26 PM
bzprinter bzprinter is offline
KLZE Engine swap questions
Help
Old 02-25-2007, 04:56 PM
96probegt's Avatar
96probegt 96probegt is offline
Re: KLZE Engine swap questions
you should change the timing belt and water pump before the install along with the valve cover gaskets and any other seals that look like they were leaking at one time as far as plugs and wires stock ones are fine to use i have heard rumours though that you should run shorter plugs in the klze because the pistons are flat and not dished like the klo3/klde
Just because its a honda dosent make it fast
96 gt-ze
2 1/4" magnaflo headers back,short ram intake ,msd,short throw shifter,eibach springs,fidenza fw,clutch masters stage 2,t3/t4 turbo install soon,poly engine mounts
www.probesnw.com
www.probetalk.com
www.mx6.com
