Old 02-23-2007, 03:03 PM
burnchassis3 burnchassis3 is offline
Exclamation Wheel bearing howl
Hello I know I have a bad wheel bearing,it has been howling for about 1000 miles,and gettin worse naturally.
My question is:
How long will it howl before the wheel locks up or falls off or whatever its gonna do?
Any ideas?
How high on my priority list of fixing does this need to go?
I replaced both front WB at 57k miles...now at 105k and they are howling again.
Thanks!
99
4.3
4wd
LT
CS
Old 02-24-2007, 10:54 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Wheel bearing howl
My question is:
Any ideas?
Thanks!
99
4.3
4wd
LT
CS
We can not answer how long.
Only make sure it is the bearing that is making the noise.
Tires and other things can setup a noise to.
But if bearing or bearings are making a noise it is time to fix /replace them.
Replace with the good quality OEM type bearings.
The El cheap O or cheaper brands may not last long.
Also if there is axle seal or hub O ring in there check/replace it to to keep the water out of bearings.
And remember the bearing/hub is what holds the wheel and brake rotor on.
MT
MT
