99 Suburban Rear Heat blower
have a blower that won't shut off after the cars is off. had to unplug it...any thoughts?
Re: 99 Suburban Rear Heat blower
You have a stuck relay, not sure where it is, probally in the engine compartment, fan goes thru relay on Hi. Should be a relay for the front fan, could try switching relays to see if prob moves to the front
Jeff |
On my "old body style" Sub there are 3 relays for the rear blower--low, med & hi. They are located behind the right rear interior panel. And a stuck relay will cause the fan to continue to run as it is powered thru the relay contacts by the "BLOWER" fuse (#3 50a) in the under hood fuse block and is "hot at all times"..............Steve
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
