Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-23-2007, 12:07 PM
steviek's Avatar
steviek steviek is offline
Oil Pressure
My buddies 97 tsi is having some minor problems. It has no oil leak and the oil filter is on nice and snug and when he's at speed it is fine. However, when the car is idling and going slowly the oil pressure gauge drops off and the check oil light comes on. I think its oil pump but A) I don't know how to get at it, B) don't know how to test it.
so If you have either suggestions on what else it could be or any answers to A,B I'd love to hear it?
Thanks guys
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-23-2007, 01:39 PM
Scrapper Scrapper is offline
AF Premium User
Question Re: Oil Pressure
if oil pump should be making all kinds of nois in motor...have you tryed sending unit??
Old 02-23-2007, 01:45 PM
steviek's Avatar
Re: Oil Pressure
no wheres the sending unit?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-24-2007, 11:01 AM
AF Premium User
should be close to oil filter...you should buy a hanes manual 4 your car....good luck....
Old 02-24-2007, 11:53 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Oil Pressure
I'm assuming your talking about the stock guage? If so, I wouldn't really trust that piece of crap. My guage in my GSX didn't work at all, but I had awesome oil pressure.
Also the oil pump is on the buttom right side of the motor. You would have to pretty much pull most of the belts off to take a good look at, because you'd need to remove the plastic covers.
But if the oil pump was taking a poo you would have alot bigger problems to worry about.
1991 GSX 2.3 Stroker
Old 02-26-2007, 07:43 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Oil Pressure
Replace the sending unit first. Mine took a crap, and the oil light would just flicker when I sat at idle. It's bolted into the oil filter bracket. It's a big round "bulbus" looking thing.
Just be careful when you install it. It is really easy to overtorque the sensor and crack the oil filter bracket. The torque is something like 5 or 6 INCH pounds, but check your manual to be sure.
And don't even think about asking how I know that.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-26-2007, 01:32 PM
steviek's Avatar
Re: Oil Pressure
Thanks alot really good to have you back on the forums
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-26-2007, 02:06 PM
Re: Oil Pressure
Thanks!
Things were getting a little stressful around here, so I thought I would take a break for awhile. Everything seems to be getting back to normal, but I noticed that there isn't nearly as much activity as there was before.
1997 Spyder GS-T
5-Speed
