Old 02-23-2007, 11:45 AM
getblazed00 getblazed00 is offline
Send a message via Yahoo to getblazed00
knock sensor for 2000 blazer
Does anybody know if the DTC PO 325 knock sensor 1 circuit malfunction (bank 1 or single sensor) is referring to the drivers side or the passenger side knock sensor? I bought the part already but I don't want to tear down both sides today to fix it.
_____________________________
2000 4x4 4dr 4.3 K&N Cold Air Induction, Flowmaster 40 series 3" catback split to dual
Old 02-23-2007, 01:04 PM
old_master's Avatar
Advisor/Moderator
Re: knock sensor for 2000 blazer
Any reference to "Bank 1" for knock sensors and oxygen sensors, is always the bank that the #1 spark plug is in.
Old 02-23-2007, 02:17 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome on your first post on AF.
Double check that code no.
If you have a code 325 it is not a knock sensor code but rather a knock sensor module code.
Has the pcm/vcm been swapped or changed or opened up.
The knock sensor module is located inside the little cover on the VCM.
Is it in there?
Also clear code and see if it returns.
And check wiring to knock sensors and VCM.
MT
