Go Back   Automotive Forums Car Chat > Ford > Fiesta
Old 02-23-2007, 06:18 AM
stormin7315 stormin7315 is offline
Steering stiffness
I have a mk3 fiesta with power steering.Problem is the steering seems jerky while turning Have renewed one track rod end and one lower suspension joint thinking that was the problem but this has made no difference.Any ideas please.
Old 08-05-2007, 05:15 AM
scwilliams2007 scwilliams2007 is offline
Question Re: Steering stiffness
Hello Mate,
Is it harder than normal to turn the steering wheel, and the steering wheel does not self-center when you let go?
If this is your problem, this a "feature" of the MK3, whereby the Steering Column UJ siezes, and spraying WD40 loosens this up.
HTH.
Old 09-16-2007, 11:19 AM
denisond3 denisond3 is offline
I dont have a Fiesta, but on several others cars, that symptom was a sign the regulator valve inside the power steering pump was sticking. It usually was worse when you first drove the car, and would improve after things warmed up. Sometimes flushing all the inky p.s fluid out would help, & sometimes it really needed a new p.s. pump. Usually the pumps were beginning to leak from old age anyway.
