Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-22-2007, 12:43 PM
'97GS-T '97GS-T is offline
Send a message via AIM to '97GS-T
car cuts out when it starts to build boost.
just put a new motor in the car (not used). boost spike to 20psi the first time, the second time is when it started cutting out. car cuts out when boost hits about 0. Any ideas what could be wrong ?
Old 02-22-2007, 12:45 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: car cuts out when it starts to build boost.
It would be very helpful if you could tell us more about the car. Mods? Maintence? Turbo? etc.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 02-22-2007, 12:58 PM
1997 Eclipse GS-T, 16G turbo, 3" full exhaust etc.
Old 02-22-2007, 01:55 PM
Scrapper Scrapper is offline
AF Premium User
Question Re: car cuts out when it starts to build boost.
whens the last time have you changed plugs??
Old 02-22-2007, 02:46 PM
put new plugs in it when i put the motor in 3 days ago. the car free revs fine but you can not hold the car at a higher RPM without it cutting out or when you are driving the car and the boost hits 0 it does the same thing.
Old 02-22-2007, 06:44 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Cuts out as in shuts off, or just will not boost at all?
95 Talon TSI AWD
97 Eclipse GST
Old 02-22-2007, 09:05 PM
like will not build boost.. almost like a rev limiter.
Old 02-23-2007, 02:07 PM
AF Premium User
Exclamation Re: car cuts out when it starts to build boost.
well another thing it could be is tps...i had a park avenue that when i started it it ran fine until i give it gas it would cut out just setting there..
Old 02-23-2007, 02:30 PM
but you can drive it.. it will also free rev, but it will cut out when you try to hold a steady rpm.
1997 Eclipse GS-T - 16G turbo, 3" exhaust, manual boost controller, turbo timer, front and rear strut tower braces
