Slow on take off????
SOHC motor with ram air intake, no exhaust yet. are all these motors very slow on take off?? and i have noticed it does run pretty fast when it gets momentum.
Re: Slow on take off????
yeah they are slow off the line, they have no torque. And if by ram air intake you mean a short ram intake, that will make it even worse.
What SOHC motor is it?
and yeah stock civic's are pretty slow if you havent noticed.
2002 Acura TL Type S 1991 Honda Crx Si |
its the d15b7, ram intake will make it worse???how???
also would it be a better option to supercharge, i found a guy selling a jackson supercharger for d series engine (whole kit) for 850.
A short ram will hurt your low end power because they are made for optimum high rpm power. Basically you're shifting your powerband into the higher rpms. So while you're gaining high rpm power, you're trading off for less power at lower rpms. Similarly, most aftermarket intake manifolds have shorter fatter runners, because they're made for high rpm power. So while a company advertises hp gains, they only refer to top output power. And most cars (especially daily drivers) don't see that high of an rpm most of the time.
With a supercharger you're only going to get so far. It will do what you want it to do, and instant boost of power right from a stop. But the engine you have now is pretty weak and isn't going to take a ton of abuse for too long (could last a few months, could last for a few years). Stock engine internals aren't ment to handle that kind of power, especially the rods and more specifically the rod bolts. Honestly your best bet is to save your $ and buy do an engine swap. |
yeah, youre right might as well save for a swap, i am aiming on a b18c5 motor if i do.
thanks. |
VTEC = Vertually Torqueless Economy Car...
Timing could be off
Carbuerator could need cleaning Air filter is dirty Fuel injector is dirty(if you have one) Didn't let it warm up enough if it's old and it's cold out(that's why mine does the same thing)
Hydrogen Conversion Kits reviewed - Can You Run Your Car On Water?
