Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 02-21-2007, 08:53 PM
Jeanette656 Jeanette656 is offline
Question 93 villager problems
Yesterday I bought a 93 villager, today it appears that was a mistake! The van will not blow heat at all. I changed the thermostat today and now not only is there still no heat, it began overheating, and the fan belt started squeeling. Also while driving, once in a while the engine seems to loose its power, almost like its not getting fuel, but if i take my foot off the gas it idles fine.This only happens for about half a minute then its fine. Are these problems related? I was thinking the heater core may be plugged...but would that cause the engine to miss? If anyone can give me any advice on what to do I would greatly appreciate it.
Old 02-22-2007, 12:24 AM
dzus dzus is offline
Re: 93 villager problems
No heat/over heating; blocked heater core or air in coolant system.
Loss of power;may want to try a new fuel filter.
Problems not related.
Old 02-24-2007, 05:13 PM
It turns out the van was air locked.....as far as the bad miss goes ive changed the plugs, wires, fuel filter and distrubitor cap and it still has the miss. I thought id try the o2 sensor next, can someone tell me where to find it?
Old 03-01-2007, 05:18 AM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
How many miles are on it? Explain the mis. What type of fuel are you using and the overall condition of the van.
Old 03-25-2009, 03:59 PM
fix my car fix my car is offline
I may be able to help with your engine problem. I had the same problem. Check all your vacuum lines. I found bad line connected to my vans EGR valve. Replaced and fixed the problem!
