Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-21-2007, 08:23 PM
marktruck marktruck is offline
98 Jgc Quits After Muddy Pull
Hi everyone,
I have a problem, I pulled A trailer out of some weeds /bushes with a chain
for about 20'. After I stopped The motor shut down and now won't start.
It doesn't seem to have any power to the fuel sending unit or the fuel pump
I can't find any wires loose at the fuel pump, but it has 178000 miles so I changed it anyway . I did find the wires pulled out of the oxy. sensor on the cat.but the wireing harness seems to be ok.I put in new relays & checked all the fuses I could find in the kick plate & under The hood. I got A complete sevice manual from jeep for My model which may take a year to understand what the problem could be. I have some machanical ability rebuildt a few motors, changed clutches, trans,brake jobs on My own stuff I have 11 cars / trucks. but MY 98 JGC is the Baby girl of the bunch. Any ideas what could be wrong ?,can the PCM go out like that ? I think oxy. sensor wires have been off for a long time cause the cel has been on for some time.My son has been driving it for the last 2 years, but it was running great until this happened.
Thanks,
marktruck
Old 02-28-2007, 11:33 AM
Mud_Limo Mud_Limo is offline
Re: 98 Jgc Quits After Muddy Pull
check the fuel pump fuses/relays, then make sure that none of the wiring harnesses to the fuel pump/sending unit caught something and disconnected. does the engine crank over when you turn the key, or does it just sit there and mock you silently?
Old 03-04-2007, 03:56 AM
(check the fuel pump fuses/relays, then make sure that none of the wiring harnesses to the fuel pump/sending unit caught something and disconnected. does the engine crank over when you turn the key, or does it just sit there and mock you silently?)
It turns over good & checked all that, I think We figgerd it out (see my post about installing a PCM.
Thanks,
marktruck
