Old 10-03-2002, 08:26 PM
RickDaTuner's Avatar
RickDaTuner RickDaTuner is offline
JDM Engine swaps
so what exactly goes into swaping a B16a 1st gen into a Fourth gen Civic or a Crx? in term of wires and clutch conversions i mean
im trying to gather enough info to do swap in my friends 91 CRX Si, ive done afew swap in the past, in my own car a 92 civic hatch, swaped in a D16Z6 into a Vx and also a JDM B18C into another EG aswell but wehne i try to find info on the Crx i cant find any
"Dude you must be a Shinto Munk, cuz i aint never seen so much love for rice on a car!"
AF'S
BROWN BOY CREW,
CARAMELO CREW
Old 10-07-2002, 10:39 AM
kaytec4door kaytec4door is offline
well dude doin that swap is fun but it will test u at times. i did a B16A swap0 into my friends 89 CRX si. the swap isnt hard its all jus the little stuff that is a pain. u have to make a custom wiring harnes for vtec to work and u cant forget to bash the frame in so the altenater pully will fit. i would suggest a place racing mount kit. ask me if u need more info.
Old 10-07-2002, 11:14 AM
91civicDXdude's Avatar
i was under the impression that a b16a1 would fit right in our cars, seeing as how they come out in them in japan. I just dont see the honda plant foreman saying, "Fujiitsui, make sure you pound the frame in so the alternator pulley will fit!"
If it came stock, you would think that it would just bolt right in.
Old 10-07-2002, 11:38 AM
91zc 91zc is offline
You need to make a dent for the pulley because of the way the aftermarket mount kits place the motor. You also need to bash down the lip of the rear crossmember so the rear motor mount bracket does not rest on it and cause uneccesary vibration. Otherwise the motors fit in just like stock with the aid of a mount kit.
91 civic 4dr
b16a
14.8@94
Old 10-07-2002, 11:50 AM
thanks 4 supporten me on that mr 91zc and your hood may not fit very well either. trust me i know i did a b16a swap into an 89 crx
:smoker2:kaytec4door:smoker2:
mods done: AEM cold air intake,
ractive racing cat,
ractive axel back exhaust,
NGK plugs,
nuespeed cross-drilled rotors,
EBC the green stuff pads,
projecter headlights,
clear corners,
carbon fiber tails,
Z3 fenders,
adjustable coilovers,
Konig flatline rims with dunlop fm901 (17*7),
full complete sound system with two 10'' subs,
kenwood 600w amp,
punch cap,
pionner speakers all the way around,
full custom interior paint job,
reverse indiglo guages,
aluminum gauge bezel,
d16a6 head swap polished,
4-2-1 ceramic coated header,
:finger4: proud member of team kay tec:finger4:
so the jdm SIR or whatever that comes out with b16a1 stock has a motor mount kit?
Old 10-07-2002, 11:58 AM
The civics/crxs that came stock with the b16a have different motor mounts. They are located slightly different than USDM civics/crxs. That is why we have to use a mount kit to swap a b series motor into our cars. Or some people cut out the old mounts and weld in new ones. I prefer the motor mount kit...makes the swap a lot easier. The hood may rub. I luckily have no problems with my hood rubbing. It is possible to adjust the height of the hood as well.
91 civic 4dr
b16a
14.8@94
Old 10-07-2002, 06:08 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
HOW!?
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-07-2002, 06:42 PM
89bxci-vic 89bxci-vic is offline
Send a message via AIM to 89bxci-vic
:bandit: i would suggest u get an hcp b-series mount kit, it sits the engine back more towards the fire wall so that the axles align better and plus it gives u more space for turbo. it also has four mounts instead of three. also order the harness from hasport, its $300. but its wourth it in the long run. holla back.
you almost beat me?
you never had your car!
Granny Shifting! Stressed cause your girl's on my lap! Don't worry you'll catch'em in the turns, slow cars can be fun too!
Old 10-08-2002, 03:56 AM
maybe no one knows this, but i know that del sol VTEC has a b16a3 in it but del sol also comes out with d16z6. so the del sol with the b16 has different motor mounts than the si right? it has to because d16z6 will bolt right in but b16 will not?
Old 10-08-2002, 05:18 AM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
People do know that the del sol came with both variations of motors, I'm almost positive the b16 version is setup with different mounting system than the sohc versions, but believe everyone when they tell you that the b16 will not just drop in.
Old 10-08-2002, 08:04 AM
The newer civics have different mounting points than the 4g/2g civic/crx. The d series motors in the 5g up civics mount the same as in our cars except on the transmission side they are quite different. The b series motors can be bolted into the 5g/6g civics using stock motor mounts from a combination of different cars ie integra, civic si, etc. The difference in mounting is due to the hydraulic transmission. This is why when you swap a d16z6 most people use a 4g cable transmission. It is difficult to fabricate a new mount for the hydraulic transmission. The b16a3 del sol has the same mounting points welded to the chassis as the d16z6 del sol but it uses different rubber insert mounts.
91 civic 4dr
b16a
14.8@94
dakota engine swap jpuckett13 Dakota 0 08-23-2010 08:21 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 10:40 PM
JDM---Engine Swap---JDM placham Corolla/Matrix/Voltz 2 02-21-2004 07:03 PM
@--- complete JDM ENGINE swaps 4 sale ---@ jspecengines '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 01-18-2002 04:42 PM
@--- complete JDM ENGINE swaps 4 sale ---@ jspecengines '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 01-13-2002 08:58 PM
