Old 10-03-2002, 07:25 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Help ME
ok my distributor on my crx DX 1.5l died on me the other day, so i took the dizzy off my friends SI 1.6l and installed it, problem is the si dizzy has wiring for a TDC/Crank/CYL sensors, where as my DX only had the TDC/Crank sensor, so i tied off the other two wires and re wired the SI dizzy to fit my DX.
after lining up the rotor to the old location, and installing everything, i got the car to start up, but the rpm would rise and fall from 1250-1500rpm constantly. i cut it off, and tried again, but the car will not start now, it'll crank tho, and if i crank it enough, eventually the check engine light comes on reading 8, which is TDC/Crank sensor.
So im at a loss here, i checked my vacuum lines, and im sure the timing is not far enough off to not start as i put the rotor in the same way i took it out. So if anyone has an idea lemme hear it.
Also, what is the best D series engine(HP,TQ) that i can bolt upto my DX tranny?
Thanks Guys.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-03-2002, 07:29 PM
GTA's Avatar
GTA GTA is offline
Whee..
either d16y8 or d16z6 (the SOHC Vtec's) or a ZC. Both those will bolt up to the tranny
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-03-2002, 07:37 PM
crxlvr's Avatar
which cars did the y8 and z6 come out of(civic EX's but what years?), i know the ZC, but i want something with better aftermarket support.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-03-2002, 07:48 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Damn man, i havent seen you here in a LONG ASS time! Welcome back, hows the car man? any new pics? have you painted the hood and the kit and everything?
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-03-2002, 07:51 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
D16z6's are from the 92-95 civics, and the y8 is from 96-00 civics. I got a D16Y8 at the local junkyard for $900. You could find one for alot cheaper than that, but this one had less than 8000 miles on it, so I spent the extra $$.
The specs are almost the same as the ZC.
They have 10 hp less than the DOHC ZC, and only 2ft/lbs less on torque.
Old 10-06-2002, 04:55 PM
crxlvr's Avatar
the car is under the weather right now, and im about to paint it when this nonsense started, so i gotta fix it first, then the paint job, cuz i just put on the kit.
Aerogear Hy-bryd sides and the wings west rear.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-06-2002, 05:00 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
you car will never run right unless you get a SI ecu. you can not mix and match dizzy & ecu. get yourself a Si ecu or a Dx dizzy and your problem is solved.
ask slammed89Si...i just helped him with this problem a month or so back
EDIT: it's slammed89civic....sorry audi
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-06-2002, 05:07 PM
amy@af's Avatar
Re: Help ME
i almost forgot...you can bolt a ZC, d16a6, d16z6, or d16y8 to it. however, the DX tranny was geared for ecno daily driving. the Si tranny was geared for performance. i'm not into the DX tranny. IMO, it is worth every penny to pick up a Si tranny...even for that d15 you got going on.
slap MPFI, ECU (needed for dizzy and MPFI), and Si tranny...you might as well start calling it a Si....seriously. then when the d15 goes you're ready to pull it and drop in a d16z6 or d16y8.
Old 10-06-2002, 05:11 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Sup man, it has definatley been a while since you have come on here.
I am thinking of doing MPFI also, but no time, so I will just stick with the DX tranny, and Dual Point on the SOHC ZC
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 10-06-2002, 05:36 PM
crxlvr's Avatar
yeah i havent been on cuz my comp is more f'ed up then my car, but you guys are the masters, so i guess its off to the yard to find me a dizzy to play with. or better yet a new engine.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-06-2002, 06:12 PM
kris's Avatar
kris kris is offline
Off playing with fire.
What died on your dizzy?
Say, if the ignitor fried, you can swap the ignitor from the Si dizzy, into your dizzy.
Old 10-06-2002, 09:47 PM
MyFirst4G's Avatar
not to mention but you have a Auto also, so you cant put in a manual ecu in to your car, or else it wont work with an auto tranny
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 10-08-2002, 10:57 AM
crxlvr's Avatar
well the entire dizzy seized, it wouldnt spin anymore and the rotor was cracked so i tried to just rewire the D16 dizzy onto the harness in my DX, guess it aint gonna work.
i might just go ahead and go for a swap now, b16 if i can.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 10-08-2002, 11:16 AM
amy@af's Avatar
whatever you end up doing...let us know! you can e-mail [email protected] (jon) and he will most likely have a dizzy for you (for time being) and cheaper than a junkyard.
Old 10-08-2002, 08:12 PM
MyFirst4G's Avatar
cheaper than a junkyard?? holy tamale!! i gotta eMail this guy!!!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
help me help me help me please fuel pump help my90horsy Mustang Talk 16 12-05-2003 09:38 AM
help i need help i need help i need help i need help lamborghiniman Diablo 1 11-24-2003 01:33 AM
Help Help Help Help Help lewdaka03 Jetta/Vento/Bora 1 06-02-2003 01:57 PM
Help Help Help Help Help Help Help Help Help Help del_blond '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 04-05-2002 03:05 PM
Help Help Help !!!B20b!!! Help Help Help HondaCivic405 Engineering/ Technical 0 04-05-2002 01:51 PM
