Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-20-2007, 10:41 PM
kg6jvz kg6jvz is offline
1990 Caprive V8
k so i just bought a 90 caprice it runns great nice and smooth but it occasionally stall at stops and when i shitft. i just got a major tune up from my mechanic and he changed all components of a tuneup. I also asked him to lok at the fuel pump he said it was fine .. What could be the problem ?? EGR valve or what? if that were is it located so i can change it?
THANKs
Old 02-20-2007, 11:10 PM
mike561 mike561 is offline
Re: 1990 Caprive V8
I have a feeling thats what im going to be in for, my caprice seems that it could sure use a major tine up as well, around how much did all of that cost??? i want to know kind of what to expect...
2006 Chevy Cobalt LS
Old 02-20-2007, 11:55 PM
Re: 1990 Caprive V8
well i spent about 400.00 at smog pro for a major tune up and oil change .. i chose them because they are walking distance to my house and i was the only driver home. I could have gottne it cheaper if i had gone deeper into Los ANgeles..Runs great after tune up no rough idols. but it still stalls... and after reading the other posts in the caprice frum i thin k it is the EGR valve which i b ought from autozone online for 50 bucks. now installing it is a different i have no idea were it goes.
Old 02-21-2007, 01:10 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1990 Caprive V8
It's located on the intake manifold near the TBI unit and on the passenger side.
It could be the EGR, but there could also be a vacuum leak (although since this is a speed density EFI system, a vacuum leak should cause it to simply run at a higher RPM), or more likely a dirty IAC motor.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-21-2007, 11:18 AM
Re: 1990 Caprive V8
yeah that is quite a high price, ill be taking the car to a friend of a friend (whos ASE certified), so hopefully he will give me a little break on costs
Old 02-21-2007, 08:58 PM
Re: 1990 Caprive V8
so after the tune up a egr repalcement and a throttle sensr replacement( 2 mechanics said it needed to be replaced.. 30 bucks plus some time>) the car doesn't stall at stops. unless i turn on the A/C at the stop. what elese could be the problem?
Old 02-21-2007, 09:42 PM
Re: 1990 Caprive V8
were is the IAC motor located?
Old 02-21-2007, 09:48 PM
silicon212's Avatar
Confoundingly Lucid
Re: 1990 Caprive V8
It's on the TBI unit.
Old 03-20-2007, 01:30 PM
at1212b at1212b is offline
Re: 1990 Caprive V8
I've had very similar problems for my 89 9C1. It would stall when warmed up, and when stopped, or going into reverse, or when the steer wheel was turned (at low very low speeds) Had a vacuum leak but fixed, and EGR was cleaned out (EGR solenoid might be a source of problem). Still caused the stalling. Full-tune up was done as well.
My mechanic then identified that it was the distributor and ignition coil (forgot which one it was specifically). Once they were replaced, I haved had the problem at all.
Old 03-20-2007, 07:42 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: 1990 Caprive V8
Did they do a fuel filter in all this?
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 03-20-2007, 10:53 PM
Re: 1990 Caprive V8
Yes, it was changed with the full tune-up, plus fuel injector cleaned out, then fuel treatment (was still stalling). I also had the throttle body gasket replaced shortly after and it helped for awhile, noticing that oil pressure was also higher after, but was still stalling.
Old 03-20-2007, 10:56 PM
Re: 1990 Caprive V8
Oops, in my previous post, I meant to say once the distributor and ignition coil was replaced (old ones were shot), no stalling at all.
