Old 02-20-2007, 09:50 PM
gunitsolja gunitsolja is offline
hellllp car not running
alright guys i just got a 91 civic hatch. the only problem is the car will not run properly. i got it to start today but it woulld only stay on if i gave it gas. the exhaust was making a sputtering noise but the engine was not knocking or making any noises. as soon as i let go of the gas the engine turns right off. I checked for sprk i checked the fuel pump new spark plugs and new wires but it is still happening. I took off the distributor cap today and it was all torn up so im wondering if this could the the culprit. So tomorrow im going to get a new one but i just wanted to try to figure out if that was the only problem or not..... any suggestions
Old 02-20-2007, 11:17 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: hellllp car not running
It could be as simple as your throttle cable is misadjusted and causing the throttle plate to close when you let go of the gas. Try adjusting the cable. Are you throwing any codes?
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 02-21-2007, 02:24 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
probably one your problems....just make sure the tb isnt conpletely closing allowing no air to pass...cause that would kill the car instantly!!
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 02-21-2007, 06:18 PM
thanks i'll try to look into doing that... it was throwing a code for timing but i redidi it and it stopped throwing the code so there are no codes right now.. the car starts and then it only stays on while giving it gas and as soon as i let it go it turns right off... it also sputters the entire time but the is no knocking noise or anything coming from the engine so im guessing that it isnt a major issue...I HOPE NOT
Old 02-21-2007, 06:20 PM
how would i check it...any suggestions??? details please if u can
Old 02-21-2007, 07:59 PM
Take the intake off it and check it out...should be a slight angle to it...just mess with the TB while the car is on...I just went through the same mess on a ZC I swapped in my friends car but his is all dandy now...Idler screw was all screwed up
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 02-21-2007, 08:02 PM
thanks i guess i gotta check that out but like i said the car wont stay on unless someone holds the gas so how would i check it?? where is the idle screw??? im kinda new to this whole thing
Old 02-21-2007, 09:24 PM
also are all your sensors plugged in and vaccuum lines in the right spot cause that would also cause that....lots of factors with a car just dying...forgot to mention is it throwing any codes, passenger side under carpet count the blinks of the red light in the lil circle of the computer?????
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 02-21-2007, 10:27 PM
im not sure like i said im new to all of this so i would have to check all the sensors and vacuum line...any sugggestions on where to start??? and no the computer isnt throwing any codes at all just the 1st hello blink
Old 02-21-2007, 10:33 PM
Well after checking your TB, make sure all your vacuum lines are hooked up. Your problem could also be distributor related and you may be getting no spark unless you hold the throttle. I remember having an ignitor crap out on me and my car would just shut off at idle unless you held the gas to like 2-3000 rpm.
