Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-20-2007, 09:50 PM
speeddevil's Avatar
speeddevil speeddevil is offline
euro headlight removal
i have been wanting to remove the headlights of my car. What is the proper way to achieve this?
1987 Chevy Caprice LS 4.3L, 700R4 Trans.
Shaved Handles and Rear Deck.
Pearl Paint Job
Old 02-21-2007, 12:47 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: euro headlight removal
You will need to take the battery out of the car. The Euro-style headlights bolt on from behind, with three nuts (two on bottom, one on left and one on right; one on top in the center). Remove the bulbs, then remove the nuts using a 10mm wrench (it could be 11, I can't remember as it's been about 3 years since I've done this). There are holes drilled in the radiator support for this purpose. The headlight assembly then pulls out from the front.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
