Old 02-20-2007, 06:54 PM
bullwinkle3006 bullwinkle3006 is offline
1998 T&C brake power booster problem?
I think I have a problem with my brakes, I have to press kind of hard on the pedal to stop the van (almost like I have manual brakes), I just bought the van a week ago and it was like this when I got it. Do I have a power booster problem?
Any help or suggestions would be appreciated,
Thanx
Old 02-20-2007, 07:43 PM
KManiac's Avatar
KManiac KManiac is offline
Re: 1998 T&C brake power booster problem?
That kind'a sounds like a booster that is not boosting. Check the vacuum line going to the booster for leaks. If everything looks good, disconnect it from the booster, plug the open end of the vacuum line and start up the van, then see if it is sucking like it should. Then get a piece of bulk hose and attach to the booster and apply suction by mouth. If you cannot get the booster to hold a vacuum, you will need to replace. Otherwise, if you cannot get vacuum from the vacuum line with the engine running, the problem is with the hoses and the booster is fine. Let us know if you have any questions.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 02-21-2007, 05:14 AM
Thanks for the quick response, I'll try your suggestions and get back to you with the results.
Best Regards,
Jim
