Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 02-20-2007, 05:59 PM
Timturnswell Timturnswell is offline
powersyeering pump pulley
How Do I Get The Pulley Off The Powersteering Pump? Thanks To For The Hint To My Problem, I Took The Belt Off And The Shaft Fell Right Out.
Old 02-21-2007, 06:29 AM
rodeo02 rodeo02 is offline
Re: powersyeering pump pulley
A new pump should come with a new pulley. You'd need a gear puller or a press to remove the original pulley.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 02-21-2007, 10:36 PM
llopez llopez is offline
I used a puller from Napa to take mine off and put it back onto a rebuilt pump.
FYI: I wouldn't recommend a rebuilt from an aftermarket place - The one I put on whined louder than the one I replaced. I even used Valvoline synthetic, no help. And yes, I bled it (for the comments that are sure to follow).
Old 03-05-2007, 11:07 AM
dragos69ca dragos69ca is offline
Your input shaft is broken (from the old pump)...remember that GM had a recall in 2004 for this problem...check if your SUV was part of it.
Regarding the pulley removing, yes , you'll need a puller and for installing you should have a kit received with the new remanufactured pump.
Don't worry, in North America are sold annually over half a milion reman pumps and they don't come with pulley so you are not the first one that has to do the job. Look for the puller...all garages have one.
SS-Steering
