Old 02-20-2007, 04:42 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Finally did it! Custom frontlip for 1st Gen 3000GT !NO 56K!
I have forever been infatuated with trying to get some sort of front lip add-on onto my 1993 SL. I think lip-kits are the most economical way, by far, to add that aggressive look to a stock bumper, with minimal hassle. My 1997 Eclipse Spyder had an eBay urethane lip, and it changed the look of the entire car in a way that people would always ask what body-kit I had on there, whereas it was just a $120 urethane lip from eBay. The best $120 I have ever spend on a visual mod.
Folks might remember me as having purchased a '97'-98 bumper, trying to slap that on while retaining my pop-ups on my 3S. Didn't work; the crash bar had to be removed in order for the nose to fit, so I ditched that idea. Then, I tried a '99 bumper. I discovered that there was way too much custom work involved for it to be worth it. I just could not understand why there were no lip kits available for 1st gen 3S's. That Kaze one was rare and not worth the money (for me). So, you know what they say...where there's a will, there's a way!
So, I did something I had been planning to do FOREVER. I took a random urethane lip from eBay ('95-'96 2GA urethane lip made for an Eclipse), and hacked it onto my 1st gen GT. A summary:
1) The only way this worked was because the urethane was completely flexible and incredibly easy to manipulate.
2) The lip was obviously shorter than the 3S's bumper (see pics), so we hacked the ends off the lip.
3) Lots of long, self-tapper screws all over the place.
4) Made custom metal and plastic brackets on the underside to make sure the lip stayed put, while at the same time, had plenty of flexibility.
5) 1.5"-2" of bumper height was added due to the lip.
6) No bondo or filler material of any sort were used.
Now, I am completely aware that the lip, at present, looks a little tacky, but I am not done with it yet.The ends are too short to cover the bumper, there are bolts visible all over the place, and the design is so that it juts out a tad. I am not bothered by this, since the basic "framework" has been laid. I am going to work on those shortcomings later.
This is what the lip looks like now:
This is what I plan to paint it like (just like my Spyder):
Here are some more images:
If only the Bomex 2nd gen lip for the 3S had been urethane, it would have been great to work with.
All criticism is welcome, thanks for checking this out. I'm really happy that I finally got around to do this. Cost me $150. Another $100 for the paint (eventually) and some cleaning up of the rough edges.
-Shpyder
The daily driver. The weekend cruiser. The lazy shop hog.
Old 02-20-2007, 07:55 PM
AutostradaVR4 AutostradaVR4 is offline
Re: Finally did it! Custom frontlip for 1st Gen 3000GT !NO 56K!
damn man, thet looks amazing. The whole front of it looks great. only thing i can see that i would change is, when you extend the sides back the the wheelwell, trim them lower so it doesnt interfere with the stock vents.
If you dont mind i'd like to copy those pics and play with them on PhotoChop.
Nice wheels also, what are they?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-20-2007, 08:31 PM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
Damn that looks nice!!! How much time has it taken you so far?
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Old 02-20-2007, 08:56 PM
will post pic#3 as soon as i finish. I would like to say though, that this is definitely something I, and probably others, would be interested in purchasing...if you feel that entrapreneurial spirit
Formerly BlinkRA182
Old 02-20-2007, 09:53 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
^^ I am with Blink on this one, you could market that things. Nice work
Old 02-20-2007, 10:24 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
on a scale of 1-10, i give it a 9.5, only because the ends are too short, as you pointed out. make the ends longer to fit the 3S bumper, and that's one badass job.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-20-2007, 11:11 PM
Shpyder's Avatar
Moderate moderator
Thanks everyone! I know, I know...I definitely have to tie up a few loose ends (such as the obviously short sides, and the naked screws).
Thanks man. It took about 4 hours...but I'm really slow, so for a seasoned worker, it could be done in half the time. The hacking and mapping of the lip was really easy, but the brackets were a tad tougher, trying to see where on the underbody I could bolt them on so that the lip stayed on one place.
Yeah, that's step two. I'm still working on how to "extend" that area to the back. I'm a complete rookie at body work; it was just an idea I wanted to do forever, and finally got to it. This is my first "custom" job of any kind. I'm not a very hands-on person, so I'll be asking around to see what the best way is to finish the sides off.
Those wheels are 18x9 ADR Version II rims, discontinued several years ago (they always d/c thir best wheels for some reason), and now I can't find center caps anywhere.
Nice job on the photoshop man, I really like the way it turned out with the red pain on there. Can't wait to get it painted.
Dude, trust me...if I can do this, anyone can do this. I am the most "un-DIYselfer" there is. All I can put on is an intake, an MBC and some IC piping. The only thing that made this possible was the flexibility of the urethane. Plus, there might be other urethane lips out there that might look much better than this one. I totally chose this Eclipse lip at random.
That's a lot more than I expected, thanks. It's certainly not for everyone...lots of folks said it looked better stock. W/e floats their boat, you know. I just wanted to be a little different. Can't wait to get it painted!
Old 02-21-2007, 06:02 PM
vectorspecialist vectorspecialist is offline
i'd buy it, but yea extend the ends and its great
Old 02-22-2007, 07:56 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
I think you have the right idea, and ya tried, but to me that looks horrible. Its obvious that its not make for the car, and doesn't fit correctly.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 02-23-2007, 12:12 AM
Shpyder's Avatar
Moderate moderator
ARGGHHHHHu have GOT to be fcking kidding me!!! Just a few days AFTER I hack up a lip and drill holes in my bumper, a URETHANE 2G 3s lip comes along on eBay:
http://cgi.ebay.com/ebaymotors/94-98...QQcmdZViewItem
Old 02-24-2007, 01:16 AM
look man. even though theres no pic of that actually mounted on a 3k, in all honesty that doesnt look like something i personally would be interested in. it looks like basically an extension, where as what you made really adds a whole new character to the front of the car, mainly because of the air inlets in front. I really dont like any aftermarket front bumper thats out for the 3/s right now, but if there was a lip like yours, i would buy it.
i know, opinions are just that. but if it was my choice, i would much rather have one that looks like the one you custom fabricated/adapted.
Formerly BlinkRA182
Old 02-24-2007, 06:23 AM
u could divide it in half, and split it(i know redundant) and put it on each side and take out the middle piece on the stock bumper, and make it look like a 360 modena
Old 02-25-2007, 02:42 AM
Shpyder's Avatar
Moderate moderator
That is exactly what I had as one of my two options before I started this "project"....the second one is what I opted for in the end, and what you see in the pics. It's a little late for me now, but I think the other option wouldve worked a tad better, since there would be no sides to cover. Bah, I'm a little slow with these things!
Thanks man, I your support. I will be trying to make that side piece tomorrow, and have everything painted by Tuesday...will post new pics once everything is done!
Old 02-28-2007, 12:47 AM
planet_keeper's Avatar
planet_keeper planet_keeper is offline
like its been said, if you can get those side peices to fit better i think thats not half bad and definitly way better than anything else out there for 1g's. i'm kindof tempted to try it myself now because there are a ton of lips out there for eclipses. i'm just worried that it'll look like crap and then be out $150 bux, lol. the lack of lip kits for 1g's is frustrating.
'93 black vr4, HKS boost controller and gauge, gutted pre-cats, 3sx downpipe, intake, 18" zenetti rims, tein-s springs
Old 02-28-2007, 08:08 PM
Shpyder's Avatar
Moderate moderator
Sigh, tell me about it. That's exactly what drove me to insanity and I ended up doing this hack job
BTW. If I could do it over again, I would try a WRX urethane lip...it seems to have longer sides and appears to be a better fit from the pictures. And as for the $150, you just gotta be brave about it...definitely worth more bang for the buck that that stupid Kaze lip that I can never get a hold of!
