Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 02-20-2007, 02:19 PM
MaxCorpious's Avatar
MaxCorpious MaxCorpious is offline
Send a message via AIM to MaxCorpious
Pulsating Brakes
When I press on the brake pedal there is a pulsating feeling on the pedal. Then when I come to a complete stop, there is a slight grinding sound. I think that the rotor maybe warped on the front left wheel. Would anything else cause this behavior? I'm going to swap the left rotor with the right one to see if the problem is still there.
1998 ZX2 -- Air Intake Mod
Old 02-26-2007, 05:31 AM
KimMG KimMG is offline
AF - Advisor
Re: Pulsating Brakes
Rotors cost between twenty and thirty dollars for you car. Common causes for the rotor to warp are using air guns to install wheels. Grinding noise can be caused by worn pads.
Old 02-27-2007, 07:37 PM
Ok thanks
