Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Tech Articles and Writeups
Old 02-20-2007, 02:11 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Injectors and Fuel Pumps
Alright, I've decided to spend some time at work and crunch some numbers on the most commonly used injector and fuel pump sizes. The list below will provide you with the maximum amount of air that a give fuel system component can handle. There are some assumptions that I had to make for the calculation to function. Such as:
1) Everyone is running 93 octane fuel @ a base pressure of 43psi.
2) The Denso stock replacement fuel pump supplys the same flow, at a give pressure, as the stock Mitsubishi pump.
3) Everyone's fuel pump and injectors are working at peak performance.
4) Target AFR is 11:1
5) I can't have everyone's injectors flow tested, so we have to assume that if you bought 550cc injectors, that they flow 550cc/min.
On to the numbers
Injectors
390cc @ 100% IDC will support 27.99lbs/min
390cc @ 80% IDC will support 22.39lbs/min
450cc @ 100% IDC will support 32.30lbs/min
450cc @ 80% IDC will support 25.84lbs/min
550cc @ 100% IDC will support 39.48lbs/min
550cc @ 80% IDC will support 31.58lbs/min
580cc @ 100% IDC will support 41.63lbs/min
580cc @ 80% IDC will support 33.31lbs/min
650cc @ 100% IDC will support 46.66lbs/min
650cc @ 80% IDC will support 37.32lbs/min
660cc @ 100% IDC will support 47.37lbs/min
660cc @ 80% IDC will support 37.90lbs/min
720cc @ 100% IDC will support 51.68lbs/min
720cc @ 80% IDC will support 41.34lbs/min
750cc @ 100% IDC will support 53.83lbs/min
750cc @ 80% IDC will support 43.07lbs/min
780cc @ 100% IDC will support 55.99lbs/min
780cc @ 80% IDC will support 44.79lbs/min
850cc @ 100% IDC will support 61.01lbs/min
850cc @ 80% IDC will support 48.80lbs/min
880cc @ 100% IDC will support 63.17lbs/min
880cc @ 80% IDC will support 50.53lbs/min
950cc @ 100% IDC will support 68.19lbs/min
950cc @ 80% IDC will support 54.55lbs/min
1000cc @ 100% IDC will support 71.78lbs/min
1000cc @ 80% IDC will support 57.42lbs/min
1150cc @ 100% IDC will support 82.54lbs/min
1150cc @ 80% IDC will support 66.04lbs/min
1600cc @ 100% IDC will support 114.85lbs/min
1600cc @ 80% IDC will support 91.88lbs/min
Fuel pumps
Numbers will be arranged in the following format:
"X psi = Y lbs/min"
where X = Boost and Y = Max airflow supported by pump
Stock 2g pump
10psi = 33.29lbs/min
11psi = 32.61lbs/min
12psi = 31.90lbs/min
13psi = 31.17lbs/min
14psi = 30.41lbs/min
15psi = 29.63lbs/min
16psi = 28.84lbs/min
17psi = 28.01lbs/min
18psi = 27.16lbs/min
19psi = 26.28lbs/min
20psi = 25.38lbs/min
21psi = 24.46lbs/min
22psi = 23.51lbs/min
23psi = 22.54lbs/min
24psi = 21.54lbs/min
25psi = 20.52lbs/min
Stock 2g pump (Rewired)
10psi = 42.08lbs/min
11psi = 41.51lbs/min
12psi = 40.92lbs/min
13psi = 40.30lbs/min
14psi = 39.67lbs/min
15psi = 39.00lbs/min
16psi = 38.32lbs/min
17psi = 37.61lbs/min
18psi = 36.88lbs/min
19psi = 36.13lbs/min
20psi = 35.35lbs/min
21psi = 34.55lbs/min
22psi = 33.72lbs/min
23psi = 32.88lbs/min
24psi = 32.01lbs/min
25psi = 31.11lbs/min
Walboro 190lph
10psi = 46.48lbs/min
11psi = 45.89lbs/min
12psi = 45.26lbs/min
13psi = 44.58lbs/min
14psi = 43.86lbs/min
15psi = 43.09lbs/min
16psi = 42.28lbs/min
17psi = 41.43lbs/min
18psi = 40.54lbs/min
19psi = 39.60lbs/min
20psi = 38.62lbs/min
21psi = 37.60lbs/min
22psi = 36.53lbs/min
23psi = 35.42lbs/min
24psi = 34.26lbs/min
25psi = 33.06lbs/min
Walboro 190lph (Rewired)
10psi = 60.68lbs/min
11psi = 59.85lbs/min
12psi = 59.01lbs/min
13psi = 58.16lbs/min
14psi = 57.29lbs/min
15psi = 56.40lbs/min
16psi = 55.49lbs/min
17psi = 54.57lbs/min
18psi = 53.63lbs/min
19psi = 52.67lbs/min
20psi = 51.70lbs/min
21psi = 50.71lbs/min
22psi = 49.71lbs/min
23psi = 48.68lbs/min
24psi = 47.64lbs/min
25psi = 46.58lbs/min
Walboro 255lph
10psi = 63.53lbs/min
11psi = 62.88lbs/min
12psi = 62.20lbs/min
13psi = 61.48lbs/min
14psi = 60.72lbs/min
15psi = 59.93lbs/min
16psi = 59.10lbs/min
17psi = 58.23lbs/min
18psi = 57.33lbs/min
19psi = 56.39lbs/min
20psi = 55.41lbs/min
21psi = 54.39lbs/min
22psi = 53.34lbs/min
23psi = 52.26lbs/min
24psi = 51.13lbs/min
25psi = 49.97lbs/min
Walboro 255lph (Rewired)
10psi = 72.15lbs/min
11psi = 71.47lbs/min
12psi = 70.77lbs/min
13psi = 70.04lbs/min
14psi = 69.29lbs/min
15psi = 68.52lbs/min
16psi = 67.73lbs/min
17psi = 66.92lbs/min
18psi = 66.08lbs/min
19psi = 65.22lbs/min
20psi = 64.34lbs/min
21psi = 63.43lbs/min
22psi = 62.50lbs/min
23psi = 61.55lbs/min
24psi = 60.58lbs/min
25psi = 59.58lbs/min
Walboro 255lph HP
10psi = 64.64lbs/min
11psi = 64.19lbs/min
12psi = 63.74lbs/min
13psi = 63.30lbs/min
14psi = 62.86lbs/min
15psi = 62.42lbs/min
16psi = 61.99lbs/min
17psi = 61.56lbs/min
18psi = 61.13lbs/min
19psi = 60.71lbs/min
20psi = 60.29lbs/min
21psi = 59.87lbs/min
22psi = 59.46lbs/min
23psi = 59.05lbs/min
24psi = 58.64lbs/min
25psi = 58.24lbs/min
Walboro 255lph HP (Rewired)
10psi = 74.29lbs/min
11psi = 73.86lbs/min
12psi = 73.43lbs/min
13psi = 73.01lbs/min
14psi = 72.58lbs/min
15psi = 72.15lbs/min
16psi = 71.72lbs/min
17psi = 71.28lbs/min
18psi = 70.85lbs/min
19psi = 70.42lbs/min
20psi = 69.99lbs/min
21psi = 69.55lbs/min
22psi = 69.12lbs/min
23psi = 68.68lbs/min
24psi = 68.24lbs/min
25psi = 67.80lbs/min
Denso US EVO 8 Stock Pump
10psi = 39.96lbs/min
11psi = 39.10lbs/min
12psi = 38.12lbs/min
13psi = 37.31lbs/min
14psi = 36.39lbs/min
15psi = 35.45lbs/min
16psi = 34.48lbs/min
17psi = 33.49lbs/min
18psi = 32.49lbs/min
19psi = 31.47lbs/min
20psi = 31.47lbs/min
21psi = 29.35lbs/min
22psi = 28.26lbs/min
23psi = 27.15lbs/min
24psi = 26.02lbs/min
25psi = 24.87lbs/min
Denso EVO 8 Stock Pump (Rewired)
10psi = 51.23lbs/min
11psi = 50.36lbs/min
12psi = 49.48lbs/min
13psi = 48.60lbs/min
14psi = 47.72lbs/min
15psi = 46.85lbs/min
16psi = 45.97lbs/min
17psi = 45.09lbs/min
18psi = 44.20lbs/min
19psi = 43.32lbs/min
20psi = 43.32lbs/min
21psi = 41.55lbs/min
22psi = 40.67lbs/min
23psi = 39.78lbs/min
24psi = 38.90lbs/min
25psi = 38.01lbs/min
Denso Supra 260
10psi = 70.70lbs/min
11psi = 70.06lbs/min
12psi = 69.42lbs/min
13psi = 68.77lbs/min
14psi = 68.12lbs/min
15psi = 67.45lbs/min
16psi = 66.78lbs/min
17psi = 66.10lbs/min
18psi = 65.42lbs/min
19psi = 64.73lbs/min
20psi = 64.03lbs/min
21psi = 63.32lbs/min
22psi = 62.60lbs/min
23psi = 61.88lbs/min
24psi = 61.15lbs/min
25psi = 60.41lbs/min
Denso Supra 260 (Rewired)
10psi = 82.91lbs/min
11psi = 82.38lbs/min
12psi = 81.83lbs/min
13psi = 81.28lbs/min
14psi = 80.73lbs/min
15psi = 80.17lbs/min
16psi = 79.60lbs/min
17psi = 79.03lbs/min
18psi = 78.46lbs/min
19psi = 77.88lbs/min
20psi = 77.08lbs/min
21psi = 76.71lbs/min
22psi = 76.11lbs/min
23psi = 75.51lbs/min
24psi = 74.91lbs/min
25psi = 74.30lbs/min
Although these are the maximum values that the fuel system components can support, I do not advocate running the fuel pumps at their maximum flow. I also don't recommend running your injectors above 80% IDC. Why, you might ask.....
Lets say you are running on the 190lph Walboro @ 20psi and are flowing about 37lbs/min of air. At that point you are within the tolerance of a perfectly functioning pump. For some reason your voltage drops because of a bad alternator, or the boost starts to creep for some reason. Now you are pushing more air than the pump can support and the car starts running lean. At that point there is a chance of melting something, which we would all like to avoid.
Anyway, I just thought I would crunch some numbers so that everyone has a reference.
Also, if anyone sees any errors, let me know and I will make the appropriate corrections. There was a lot of numbers to crunch and transpose, so it is possible that I made a mistake.
EDIT -> Added additional data for injectors (750cc, 850cc, 950cc and 1000cc). Also, please note that these flow rates are calculated at the fuel pump outlet and not after traveling through the system. Just another reason not to try and approach the maximum limits listed above.
I just added the US EVO 8 stock pump and the Denso Supra 260 as requested.
I also adjusted the injector calculation because I screwed up the mass of 1 gallon of water in my calculation, which led to the incorrect mass of 1 gallon of fuel being used.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
