Problems w/ hazard and turn signal 99JGC
I have a 99 JGC that all of a sudden the hazards and turn signals stopped working. I have checked the fuses and everything looks good. It started a couple of days ago when it was cold in the am then when it warmed up, they worked fine. The driver window will not roll down now either...
What do I need to look at ? |
Re: Problems w/ hazard and turn signal 99JGC
::bump
NOBODY?? I have NO turn signals or Hazards HELP!! |
Not sure if you are aware... There are other good jeep sites like http://www.jeephorizons.com or http://www.jeepforum.com/
02 Ford Focus @ 306K 97 G Voyager 3.3L V6 @ 122K. Trans leak fixed 5/2007 94 Jeep G Cherokee Laredo 5.2L V8 @ 159K re-fixed transfer case last update : 01/23/2013 |
First thought that crosses my mind, check the bulbs first. The next idea, check your wire connectors to see if any are lose. The reason is you said they stopped working when it was cold, possible water might have got into the connectors and froze, expanding them to bust, disconnect, or just not making proper contact. As far as any other ideas... none cross my mind right now. Not if you already checked your fuses, maybe a blown LOM??? Not sure about the LOM though, I do not know how that would react if it blows or even if you have one. Not all Jeeps have one unless they are equipped with a factory towing package.
I would say the flasher is bad.Ithas a combination flasher for the turn signals and the hazards
thanks for the replies... |
No,its a flasher.Its under the dash,on the drivers side.You have to take the lower panel off to see it.The part number is 4686094,and it lists for $42.70
Does anyone know if it was the flasher that was the problem or what the problem was for this issue? bc im having same problem, Directionals and hazzards both do not work. i checked all my fuses and such soo any help would be excellent thanks in advance.
I have a 95 grand cherokee and I can't find where to put the flasher unit. I have checked under the steering wheel under lower panel and don't see it. Any suggestions?
