Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-20-2007, 01:53 PM
garydh2000 garydh2000 is offline
Very Noisy Belts ??
My 96 Rodeo has what sounds like loud, squealing belts. The belts, all belts, have been replaced within the last six months. I have had the belts adjusted since their replacement but this did not eliminate the noise. I have used belt dressing as well which seems to provide only temporary relief.
My question is: If not the belts, what might be causing this noise?
Thanks, Gary
Old 02-20-2007, 02:10 PM
Ramblin Fever Ramblin Fever is offline
Re: Very Noisy Belts ??
On my '97 - when my belts turn squeaky, it's either because they're worn or loose.
Tighten 'em up a *bit* more. 'Zu's like their belts extra snug!
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 02-20-2007, 03:16 PM
OK...I will try to tighten more. I thought maybe it could be a bad fan clutch or tensioner? Would either of these cause the squealing?
Old 02-20-2007, 04:14 PM
surferfletch surferfletch is offline
Any of the accessories can squeal, but I'll bet it's your belts, too. Just be careful with the tightening....I overdid the power steering pump belt and wound up stranded. Sounded like the engine blew up with the belt bouncing around the engine bay. Knew what it was right away, though, when I tried to turn down a sidestreet.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 02-21-2007, 09:38 AM
Cat Fuzz Cat Fuzz is offline
It's probably the alternator belt. For some reason, that one needs to be a little tighter than normal.
Old 02-21-2007, 04:02 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
I wouldnt use belt dressing anymore. It stops the squeeling by breaking down the rubber and softening it. You are still ok, you will just have to replace the belts a little earlier then normal probably. I'm an HVAC tech (commercial heating and a/c) and we dont even allow the stuff in the shop. If our belts are squeeking we have to either adjust them properly or replace them.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 03-19-2007, 12:54 PM
I had all three belts replaced last week. The squealing is gone and the Rodeo is running great.
130,000 miles now.
Gary
