Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-20-2007, 12:53 PM
1987ss's Avatar
1987ss 1987ss is offline
check engine codes
My 99 tahoe gets 10 mpg and my check engine light or ses is on had it scanned and the following codes came up PO141 (o2 heat bank one sensor 2 or something like that) and PO174 (fuel system to lean bank 2)
I guess im asking what or were would you start to fix problem?
Old 02-20-2007, 03:35 PM
maxwedge maxwedge is offline
A990 racer
Re: check engine codes
I'd focus the the o2 sensor before the cat on the pass side.
Old 02-20-2007, 04:33 PM
1987ss's Avatar
thanks!
Old 03-06-2007, 11:03 PM
1987ss's Avatar
changed it.. is there a way to turn off ses light with out the use of a scanner to clear code?
Old 03-07-2007, 09:47 AM
2000CAYukon 2000CAYukon is offline
If you fixed the problem, the light will go out by itself after a few trips. Otherwise, removing battery power for a few minutes can reset the light.
Note that if you remove battery power to reset the light, you may not pass a smog check right away due to the fact that the PCM needs to relearn fuel trims. This usually takes a week or so to pass smog after removing battery power.
//2000CAYukon
Old 03-11-2007, 03:36 AM
1987ss's Avatar
thanks guys! the light went out!!
Old 12-09-2007, 11:04 AM
susie_4 susie_4 is offline
Hey Guys withthe post for un hooking the cables and re hooking them to reset the light. I haven't tried that yet but I am going to. Thank you
