Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 02-20-2007, 12:27 PM
FliGi7 FliGi7 is offline
Question Spark Plugs - Which Ones Do You Run/Like?
I personally run NGK's on my camaro but that's a whole different ball game. I was wondering which ones everyone is running and which work best for a plain old daily driven '02 civic. I've done the rest of the tune up on the car, these are the only things remaining. I picked up some Bosch platinum's from Advance but wanted to see which ones everyone recommends before I put those in. Also, is there anything tricky to putting them in on these cars?
Old 02-20-2007, 12:36 PM
BrodyP's Avatar
BrodyP BrodyP is offline
AF -Advisor
Re: Spark Plugs - Which Ones Do You Run/Like?
Honestly OEM is the way to go. Stock Honda plugs are 100% perfect and there is no reason to change them out unless needed. Also remember your using coil packs. As we all know changing the cap, wries and plugs yield differences, but just swapping the plugs on the Civic wont do much. If you really want to change them, then yes Bosch is fine or choice from the list below. I wouldn't waist much time on your plugs, you should have over 100k on OEM plugs before thinking about swapping them out. Hope this helps
-Brody
NGK R or Denso Iridium Bosch Platinums or NGK G-power Platinum Tipped
03.IS300.MT.LSD. 'Supra in Training'
Old 02-20-2007, 02:00 PM
Yea, I'm not looking for any gain whatsoever. I'm just looking for a solid plug that will last, yield smooth performance, and won't break the bank while doing it. I figured the Bosch platinum's I got were about the happy medium. However, some plugs in my camaro don't run as well as others, so I wanted to see if that was the case with these civic's.
Old 02-20-2007, 05:20 PM
Mmmmmk, I guess plugs are not as talked about of a topic on here as I thought.
