Old 02-20-2007, 11:33 AM
4twenty's Avatar
4twenty 4twenty is offline
New Injectors for ZC??
So I'm about to drop a ZC into my 89 CRX si, i have BOSCH spark plugs and wires, new cap and rotor, purple haze deep cycle battery, magnaflow cat + exhaust.... Should I put better injectors in it? would you? why or why not?
Old 02-20-2007, 12:30 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: New Injectors for ZC??
I wouldnt, the stock ons can handle it just fine, unless you want to boost it. You could do it, but what gain would you get from it? really?
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-20-2007, 02:40 PM
4twenty's Avatar
Dont higher CC injectors shoot more fuel into the motor giving it more hp???
Old 02-20-2007, 03:17 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Not necessarily. If your ecu is not programmed to map that extra fuel, you'll just bog your engine and lose power.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-20-2007, 03:23 PM
4twenty's Avatar
well, what would be required to make, lets say - 300-400CC injectors work to their full potential, and if they do, how much hp will it add? I'm keeping my baby all motor, no boost. the only reason i would boost is for the sweet sound of the blow off valve, gotta love it haha.
Old 02-20-2007, 03:36 PM
I'm sorry but that is the most asinine reason I've ever heard of for boosting a car. But to try and answer your question... you would need like 11-12:1 compression ratio all motor to run those cc injectors. A stock 1.6 comes with 240cc injectors for a 9.1:1-10.5:1 cr engine. I'm not sure if b-series flow a little higher though. And if you didn't want to build up the motor then you'd still have to run some re-mapping software to handle the extra fuel.
2010 Honda CR-V EX
Old 02-20-2007, 03:38 PM
4twenty's Avatar
so, clearly - higher CC injectors are not a quick mod to gain hp?
Old 02-20-2007, 03:59 PM
Not particularly. I doubt you'd even need higher flowing injectors to run higher compression. I didn't and I was running 11:1 cr. Then again, my distributor failed and even with 93 octane I detonated with stock PM6 and advanced cam timing. Obviously, this is not the correct way to tune the car. But it ran like hell for a whole year before blowing up. If I still had the car and that engine though I'd have it properly tuned for sure.
2010 Honda CR-V EX
