Old 02-20-2007, 09:29 AM
godfather23's Avatar
godfather23 godfather23 is offline
Pink Primer? Whos makes that stuff? Where to buy in Europe or Germany?
Hey Guys,
Iīve been searching for a while now and I canīt find some sort of pink primer oder pink foundation (from Finisherīs) online in a shop in Europe or Germany? Where can i buy that sort of product or a similar pink primer from a different maker? The best solution for me would be a product in a spray can!
Thanks for your help in advance.
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 06-07-2009, 05:46 AM
das_auto's Avatar
das_auto das_auto is offline
Re: Pink Primer? Whos makes that stuff? Where to buy in Europe or Germany?
Hi there mr. godfather!
Sorry for replying to this ancient thread but I have seen modelers use the pink TS-25 color from Tamiya as a primer before spraying Italian red or bright red. As long as you donīt cover the model in too heavy layers you should get a nice satin surface to work with.
Priming with something like Fine White surface primer before spraying the pink though.
HTH!
Emil
Old 06-07-2009, 06:40 AM
stevenoble's Avatar
I've made my own before using Zero White Primer and adding a small quantity of Zero Ferrari Rosso Corsa Red into the primer, mixing and spraying. You end up with the same effect as what you are looking for, a pink primer of sorts.
Steve Noble
Old 06-07-2009, 09:00 AM
ales's Avatar
ales ales is offline
Forza Schumacher
I also make my own - the primer I use mixes very well with Tamiya acrylics
