Old 02-19-2007, 09:54 PM
fwdfreak's Avatar
fwdfreak fwdfreak is offline
Send a message via MSN to fwdfreak
Compressor - airbrush question
Ok, I used the search function, didn't find anything that would answer my question.
The problem is, lets say I buy a revell compressor and a Iwata Revolution airbrush, how big of a problem will it be to get the air from the compressor to the airbrush.
I am fairly sure that the hose diameters are different with iwata/revell. Currently I'm using the Revell "standard" class airbrush, and to be honest, its crap so I need to move up a notch
I hope I made myself as clear as I possibly could
Old 02-19-2007, 11:46 PM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Compressor - airbrush question
I'm not sure of the revel measurements but Tamiya/Iwata both use an 1/8 inch hose.
If you can find a place that sells air compressors (industrial type(hobby stores may not have the 'connections')), then they should be able to get you fixed up. Just bring the hose and your AB with you to show them if you're not sure of the measurements. Shouldn't cost much 2 or 3 dollars is what I paid for a 1/2 x 1/8 inch adapter.
If you don't have a hose, preferabley find one that fits your AB rather then your compressor. This way you won't have to hold the weight of the adaptor along with the AB.
HTH,
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
