Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-19-2007, 12:28 PM
jsweeter jsweeter is offline
CD player/Speakers not working right
I have a 1999 ford contour 2.5 se sport. The car has the premium sound system and we installed a dual deck and pioneer speakers in the doors. The problem is that when we turned it up the speaker in the drivers door faded away and now does not put out any sound. Pulled the speaker and installed it in my truck and it works just fine. Put it back in the car and it did the same thing.
Is this a problem with the sound system amplifier? We did hook up the "turn on amp" wire.
Where is the amp located?
Thanks in advance,
James
Old 02-19-2007, 03:13 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: CD player/Speakers not working right
Post this over in the audio forum of CEG. Theres a ton of audio gurus over there.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-19-2007, 07:34 PM
Jason43's Avatar
Jason43 Jason43 is offline
I'm no guru, but I take it you didn't bypass the factory amp(behind the glove box) when you installed the new head unit?
Just go to contour.org
1999 Ford Contour SVT
Old 02-19-2007, 10:35 PM
no, Where can i get a bypass adapter?
Why would this matter?
Old 02-19-2007, 11:11 PM
Jason43's Avatar
The stock stereo=pooh. There's nothing premium about it. If you're running an aftermarket head unit, it's more than likely putting out more power than the amp is anyways. Like I said, I'm no stereo guru, but if I had to guess, I'd say running more power into the amp than its putting out may have something to do with your problem. Get the bypass adapter from Crutchfield's and sell the amp on ebay. The "premium" stereo equipment for some reason usually sells for at least the price of a decent head unit.
