Old 10-03-2002, 03:31 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
Question throttle angle sensor
what is the throttle angle sensor. what does it do ? my ecu is giving me this code
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 10-03-2002, 07:02 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Strangely enough, it's the sensor attached to the back of your throttle that tells the computer the angle that your throttle is open
Bad news if it's stuffed or has been adjusted/tampered with, as they are factory fixed and set and are damn near impossible to reset properly outside the factory.
Easiest bet is to chuck the whole throttle body and get one complete with the sensor untouched to solve issues. The two screws holding it in place should be either star headed or some non-standard screw if it's untouched *in theory*. Mine was messed with in the SiR and I had to put an XSi one on.
Check that the wires/loom isn't detached first though, it's a black unit that is attached to the throttle, closest to the firewall.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 10-03-2002, 10:40 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I agree w/ setanta.However mine is braken right now,has been for a year and a half,but works just fine.Otherwise your gonna have to replace it if it's throwing a code.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 10-03-2002, 04:58 PM
H4Bangin's Avatar
replace the sensor or the whole throttle body?
Old 10-03-2002, 07:21 PM
GTA's Avatar
GTA GTA is offline
Whee..
gunnmen01
same here. Mines been messed for a while now. All it does is cause my idle to be weird sometimes.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 10-04-2002, 07:26 AM
Setanta's Avatar
Replace the whole throttle body (including an untampered TPS).
My issue was an idle that got higher and higher, until it was idling at 2500 hot - even more cold.
The ICV (Idle control valve) attached to the block causes an erratic idle, not the TPS, just in case someone fault diagnoses the issue wrong.
It's another case of replace with another unit.
'99 PY DC2R
'85 BBS BMW E30
Old 10-04-2002, 01:50 PM
GTA's Avatar
GTA GTA is offline
Whee..
Does this cause the TPS code to pop up? Mine just idles high sometime and sometimes doesnt.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 10-04-2002, 06:29 PM
turbcivic's Avatar
turbcivic turbcivic is offline
I work at a honda service center and we just replace the TB. The TPs are a pain to mess with.
Old 10-05-2002, 02:16 AM
H4Bangin's Avatar
hmmmm well it doesnt idle funny, when the check engine light comes on it lags when u give it gas...... could it be because i have a 1.6 block with dx injection?
Old 10-05-2002, 05:46 AM
Setanta's Avatar
Depends on the ECU it's running I guess.
I used to get lag before VTEC before changing my throttle body. If it's not idling funny then it isn't the ICV.
Check your wiring before changing the TB - if they are shorting through oil impregnation or are stripped, disconnected or otherwise rooted, that could be the issue.
'99 PY DC2R
'85 BBS BMW E30
Old 10-05-2002, 10:21 PM
H4Bangin's Avatar
cool I'll do that thanks u guys:frog:
Throttle Angle Sensor Jmrec100 Legend | RL 1 09-21-2005 04:20 PM
throttle angle sensor 97taurus '88 - '91 Civic | CRX | Wagon | Shuttlee 6 01-30-2005 12:53 PM
Throttle Angle Sensor? LancasterWannaBe Integra 2 08-20-2003 10:35 PM
Throttle Angle/Position Sensor 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 12 04-14-2003 09:38 PM
Throttle angle sensor Cav '71-'87 Civic | CRX 8 03-04-2002 11:07 AM
