Old 02-19-2007, 10:50 AM
willysunit5 willysunit5 is offline
Send a message via AIM to willysunit5
Help Tranny Problem
I WANNA KNOW IF A 88-91 HF CIVIC/CRX 5 speed TRANSMISSION WOULD FIT MY 91 civic HATCHBACK
and if it does fit would it be good for racing
Old 02-19-2007, 01:09 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: Help Tranny Problem
Yes it will. Make sure you know the year of the tranny as the 88 uses a different spline count clutch as the other years. Is your hatch currently an STD? Because i wouldn't even consider going through the trouble unless your current tranny is 4 spd. The HF tranny has a LOW final drive and LONG gears. It will not be good for performance, but you'll get great gas mileage.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 02-19-2007, 01:16 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
VERY BAD for racing.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-19-2007, 01:26 PM
yea my current tranny is a 4 seed
Old 02-19-2007, 01:29 PM
yea it is a std
Old 02-21-2007, 08:01 AM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
So your saying that the 4 spd is better for racing then the 5spd cause you can run the gears longer?
Old 02-21-2007, 10:14 AM
FrodoGT's Avatar
Not saying EITHER are good for racing lol. although I have seen inctances where because a car had a longer gear, it got faster times because he didnt have to shift again before he hit the 1/4 mi. While the shorter geared car had to hit 3rd. But still, the hf trans blows unless your planning on riding the interstate, and even then it has no balls as far as gearing goes. Try running 2.5k rpm down the highway and trying to pass anything lol
Current project:
Rio Red 91 hatch.
Old 02-21-2007, 11:10 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
The DX(I'm assuming the HF is the same) tranny is pretty much your 4 spd with an overdrive. don't expect 5th gear to really get you any speed. I have hit 105-110 in 4th gear before, shifted to 5th and drop below 100, it ended up picking back up, but took awhile to do it.
From what I understand, I know the SI tranny has shorter gears and I believe the EX is in between the SI and DX trannies.
But a general rule on swapping transmissions on Hondas, if its for the same engine series(D series for this case), they will usually interchange. There are a few exceptions like the 88 transmissions, and the 92+ will fit, but gotta convert to hydraulic.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-21-2007, 12:38 PM
The HF tranny has completey different gearing than the DX and has the lowest final drive of all trannies (around like 2.93:1). The DX and SI actually have the same gearing but the SI tranny has a much high FD (around 4.35:1). Bottom line, if you want to build a turbo/ all motor D, your best bet is picking up an SI tranny, hard to find now a days.
Old 02-21-2007, 03:39 PM
Tony's Avatar
TLD Member #1
Ok, thanks for correcting that CRXeperiment. That final drive makes a big difference between the DX and the SI. The 5th gear on the DX is pretty much overdrive, nothing more.
Tony
Old 02-25-2007, 09:28 PM
mudbuddha mudbuddha is offline
I have the PL3 - 000A 5 speed, 89 tranny with 20 splines variety... Not sure if this is an SI tranny or not - can anyone tell me? Anyways, it's pretty zippy and I get 27mpg mostly with highway use.
1991 DX HB Hybrid
1990 JDM ZC DOHC 1.6L w/ SI tranny
I/H/E all custom by shop or by myself
A/C removed, San P/S
Lightened and Balanced Flywheel(10lbs), Centerforce Clutch, Chipped PG7 ECU, Ported throttle body and portmatch runners, Auto Meter water temp, A/F guages, Matrix Tach, Type R shif knob and custom short shifter
Custom 92-98 BC kit, Fender Flares for 18s' ALT rims on Sumho Supra 225/45/18
Custom 2001 M3 Grill insert and side mirrors. My favorite(my own creations): Custom LEDs Tail Lights and Custom Bluish, Silverish, Metallic Still Water paint.
Aiwa head unit and Kenwood amp w/matching Aiwa speakers and custom door mounted tweeter...
Future Mods: Zex or NOs 65 shots dry and possibly a Supercharging system as well as a Ram Air system of my own design. By then, a full rebuilt from block to Head w/ all the goodies
1991 DX HB Hybrid
Old 02-25-2007, 11:54 PM
Generally ID numbers won't tell you what kind of tranny you have. There is a way to figure out exactly what tranny it is by rotating the crank and counting the number of turns at the differential. You can also just tell us what rpm your at when doing like 75. It sounds like you have an SI tranny though.
Old 02-27-2007, 09:08 AM
DuiSonOfDarp's Avatar
DuiSonOfDarp DuiSonOfDarp is offline
Send a message via AIM to DuiSonOfDarp Send a message via MSN to DuiSonOfDarp Send a message via Yahoo to DuiSonOfDarp
Woah only 27 on hwy, I'm gonna stick with my HF tranny I did a little over 100 miles on two maybe two and a half gallons, mostly hwy.
Old 02-27-2007, 11:43 AM
Yeah for gas mileage definitely stick with the HF tranny. Granted, its slow and all but its a commuter car so it was built that way. I miss the gas mileage my old std civic used do get with a dx tranny. Now my crx gets nowhere near what I used to get. Unfortunately, Si rexes are heavy (better stuff) and the si trans is geared too quick, even on the highway.
