Old 02-19-2007, 09:24 AM
anterazza1954 anterazza1954 is offline
Instrument Gauges Out
Got a question. Have a 2003 Silverado. All gauges have stopped working, tach, speedometer, oil pressure, gas, water, battery. Everything else works. All fuses are okay. What's up and what will it cost.
Old 02-19-2007, 07:17 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Re: Instrument Gauges Out
Are you referring to the cluster lights, or the needles?
*Under Construction - New sig to debut*
Old 02-19-2007, 07:44 PM
needles
Old 02-19-2007, 10:27 PM
FiTxAg04's Avatar
FiTxAg04 FiTxAg04 is offline
Sorry to interrupt, but is it possible (and easy?) to change the cluster bulbs?
2004 Chevy z71
BF Goodrich T/A KO 285/75/16s. Flowmaster 40 Series exhaust. K&N intake. Stull billet grille. F-150 torsion bar index keys. 800w stereo system.
Old 02-19-2007, 11:19 PM
rjeffery rjeffery is offline
anterazza1954, do a search. There has been a number of posts on this topic in the last few weeks. You will probably get more info that way.
Old 02-20-2007, 05:15 AM
NOT BULBS! They do not move when engine is turned on.
Old 02-20-2007, 04:59 PM
kyleworm kyleworm is offline
Post Re: Instrument Gauges Out
Hi. I had the same problem with my 1999 silverado. I had to pull the instrument cluster and unplug the wiring harness and rerout the harness to the left. Repluged back in and everything worked ok. Hope this helps
Old 02-20-2007, 07:15 PM
I found out from a certified mechanic that the speedometer cluster needed replacement. Apparently GM has had a number of problems reported with these "needle" gauges.
Old 02-20-2007, 07:17 PM
No, apparently not. The panel has to be pulled out before replacing bulbs, from what I have learned. Anyone out there know any differently, let me know.
Old 02-20-2007, 08:24 PM
mcconnell45 mcconnell45 is offline
Check This Thread And See If It Helps Any http://www.automotiveforums.com/vbul...highlight=Tach
Danny-
2008 Silverado LTZ Z71 Extended Cab
"The Winner isn't the one with the fastest car, it's one who refuses to lose." #3
Old 02-21-2007, 11:17 AM
muff34 muff34 is offline
try Kyleworms suggestion . I have read also where sometimes the solution is unplug and re-plug cluster
Life Is A Highway ,Enjoy The Ride
