Old 02-19-2007, 08:09 AM
91S10's Avatar
91S10 91S10 is offline
Send a message via AIM to 91S10 Send a message via Yahoo to 91S10
Clutch slipping possibly??
I have an 89 civic hatch and when im driving in 3rd gear and i go to get on it, it just revs up like the clutch is pushed in or something, so i drop it into 2nd and it does the same thing, but when i go back into 3rd it stops. My friend said his car did it to but only when it got cold outside. and that has been the only time mine has done it, when its cold. Could it be just cause its cold or could it be the clutch/tranny? thanks for your help!
Old 02-19-2007, 09:48 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Clutch slipping possibly??
Sounds like the clutch is going out to me. The only time I have seen weather really effect a clutch is mainly on Hydraulics, but might happen on a cable too.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-19-2007, 09:58 AM
91S10's Avatar
Ok thanks, sorry bout the multiple post, my colleges internet sucks.
Old 02-22-2007, 01:14 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
try to tighten the clutch cable. follow the cable from the cabin to the trans and you should see a knob by the batt. spin it, not sure wich way, to tighten...
Old 02-22-2007, 01:19 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Righty tigthy lefty loosy, like any other bolt. You shouldn't have to adjust the cable unless the pedal is engaging too early or too late, but give it a shot. A bad clutch will slip at a certain engine rpm, so if you try revving your engine when in gear and you notice it slipping, you have a bad clutch.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 02-22-2007, 03:52 PM
91S10's Avatar
It only revs it when im in gear. it started to do it today, then i let off the gas and got back on it and it stopped.
