Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-18-2007, 11:12 PM
Blazerboy1287's Avatar
Blazerboy1287 Blazerboy1287 is offline
Send a message via AIM to Blazerboy1287 Send a message via MSN to Blazerboy1287
Recent Rough Idle and Low RPM problem
I just got back from driving from San Luis Obispo, CA, to Camarillo, CA. I got a tune up about a month ago, and changed oil about last week to mobil 1 synthetic 10 30. Anyways, When I was almost back to Camarillo, I noticed that my car would bog in the 2k to 3.5k rpm range or when trying to accelerate, similar to if i was trying to take off at 1500 rpm or less. The condition got worse, and when I got off the freeway and was sitting at the light, the idle fluctuated from 500rpm to 750 rpm and was rough. Any ideas on what could cause this? it was running fine when i started the trip.
btw my car is a 97 eclipse gst with about 101k miles on it, all stock.
Black 1995 Blazer LT 4 Door 4x4 *SOLD*
@110000 miles
3-inch piping with a Flo-Pro V-Force Muffler
97 Eclipse GST (Burgundy) (powered mostly by Ebay)
123000 miles
Short throw Shifter
Ebay true 3-Inch Stainless Steel Catback
Ebay Intake w/ K&N filter
GSX dual piston upgrade
Powerslot Rotors
Akebono Ceramic pads
All synthetic fluids
"It is only after you have lost everything that you are free to do anything."
-Tyler Durden
Old 02-18-2007, 11:44 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Recent Rough Idle and Low RPM problem
boost leak
now - 2000 civic
soon - 2002 is300
Old 02-18-2007, 11:59 PM
smoke121212's Avatar
smoke121212 smoke121212 is offline
i got a similar problem. really rough idle. mitsubishi eclipse gs.
Old 02-19-2007, 12:08 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
I'm trying to restrain myself... I'm editing all of my posts..........
DSM geek
Old 02-19-2007, 12:14 AM
Mr. Blazer. Do you have any check engine lights on? Boost leak aside, I believe it is more of a spark issue with your hesitation problems. The bumpy idle very well could be a TPS/ISC 2g issue. It may need readjustment. You need to do a boost leak down test, then test the TPS via FVAQ.com
DSM geek
Old 02-19-2007, 12:36 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Try not to jack other peoples threads, if you have a problem, you should start your own.
Blazer, I agree with crunchy and scott, do a boost leak test and then check the sensor(s) situation.
95 Talon TSI AWD
97 Eclipse GST
Old 02-19-2007, 12:41 AM
let it go man
now - 2000 civic
soon - 2002 is300
Old 02-19-2007, 01:01 AM
Okay, will check. Is that something that could have happened while I was driving on the freeway? because it just started while i was on the 101.
and how does one perform a boost test? I got the car a month ago, and haven't had a turbocharged vehicle before
@110000 miles
123000 miles
Short throw Shifter
Powerslot Rotors
-Tyler Durden
Old 02-19-2007, 01:02 AM
and no, I do not have any check engine lights on. Seems strange that the spark would be bad because I got the plugs replaced about a month or less ago.
@110000 miles
123000 miles
Short throw Shifter
Powerslot Rotors
-Tyler Durden
Old 02-19-2007, 01:03 AM
Yes, it could happen at any time.
http://www.vfaq.com/mods/ICtester.html
95 Talon TSI AWD
97 Eclipse GST
Old 02-19-2007, 01:07 AM
Thanks for the information. It's too late to get anything now, but I'll check it out tomorrow. I'll be back when I find out what's up.
@110000 miles
123000 miles
Short throw Shifter
Powerslot Rotors
-Tyler Durden
Old 02-20-2007, 12:53 AM
mmmmkay... no boost leak. ran around town getting the stuff, because one hardware store has pvc cap but no band clamps, one auto shop has radiator hose but no valve stems. Checked the TPS/ISC and no problem. The spark plugs are fine as well. The car is currently undergoing diag. only at the mechanic, because i'm too busy to do it myself and it's only one hour of flat rate, and i'm gonna see what's wrong. Anybody want to guess what he's going to find?
@110000 miles
123000 miles
Short throw Shifter
Powerslot Rotors
-Tyler Durden
Old 02-20-2007, 02:39 PM
Update: Verdict is I need Plug Wires and an injector service. The mechanic wants 300 bux. HaHa. Fortunately, I work at a dealership, and can do this for cost of parts. which comes out to... whatever the wires are. Any recommendations for wires?
@110000 miles
123000 miles
Short throw Shifter
Powerslot Rotors
-Tyler Durden
Old 02-20-2007, 09:05 PM
Uhh...yeah, go to Autozone and get some regular aftermarket wires, they'll probably be 1/1000th of the cost of OEM. And "injector service", what the hell is that?
95 Talon TSI AWD
97 Eclipse GST
Old 02-21-2007, 12:10 AM
it's another way to say "waste of money." I changed the plug wires and dumped some dupont fuel injector cleaner into the tank. 60 bucks later, she runs like a champ. What i don't get is how the plug wires went to hell so quickly. It's like one minute they were fine, the next minute, crap.
@110000 miles
123000 miles
Short throw Shifter
Powerslot Rotors
-Tyler Durden
