Old 02-18-2007, 10:58 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
obd0 to obd1 question
Hey guys, been a while for me on here. I've had my d15b vtec in my crx for over a year running obd0. I finally have the ecu and jumper harness and im ready to convert. My question is can i continue using my old manifold and tb? Is it a must that i use the d15b manifold?
Cheers, Vince
Old 02-18-2007, 11:30 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: obd0 to obd1 question
No, you will need the obd1 sensors and I believe injectors. But the manifold will be fine.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-19-2007, 02:13 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
????....you will only need to get a obd1 dizzy and get rid the resister box and solder those wires :-)...what ecu are you using???make sure you ave one that wont look for a knock sensor
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 02-19-2007, 08:46 AM
P08 ecu is what im running. so ill just use the obd1 dizzy. Get rid of the resistor box...uhoh... didnt know about that one... lol a little help?
Old 02-19-2007, 08:55 AM
FrodoGT's Avatar
eh, im a noob at 2am. Sorry
Current project:
Rio Red 91 hatch.
Old 02-19-2007, 12:29 PM
oh, and whats this o2 sensor stuff? I read that I can keep the 1 wire o2 sensor with the p08 ecu, correct?
Old 02-20-2007, 08:09 PM
your right on the inectors mate and he will need the clips I jsut provide him with a good link for a noob :-)
http://www.honda-tech.com/zerothread?id=635580
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 02-21-2007, 12:11 PM
Thank you very much, I do appreciate it, but it still doesnt answer my question about the 1 wire o2 question. Do I just leave it as it came in my si for the d15b vtec swap or not?
Old 02-21-2007, 07:56 PM
ECU is a 'small case' P08 (this will run with single wire 02 as thats what VTi/VXi came with). VTEC point is at 4800-5200 rpm (4800 @ WOT), while the rev limit (fuel cut off) is at around 7350 rpm. P08 has fairly leaner maps with more timing advance then the P28/D16Z6 ecu A USDM p28 can be used longest 4-wire 02 is used and you don't mind the slight performance decrease. But no worries it can be easily chipped to P08 specs.
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 02-21-2007, 11:27 PM
Thank you rider, I have the p08 ready to go, so all is well correct?
Old 02-22-2007, 07:25 PM
yes....have any problems just aim me at yz125rider21...peace
90 Honda CRX Si
-Red/Black
-B20B/b16
