Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 02-18-2007, 01:20 PM
Cablekid Cablekid is offline
Shift INDICATOR
Hey I got an automatic tranny, and for some reason all the sudden My Shift INDICATOR The thing under the speedometer, PRND12
Well Park is Reverse and N is Reverse D is Neutral and 2 Is Drive 1 is Second and than after on the bottom its 1
Understand? it is like the Needle thing is off. How did this happen? and is it an easy fix?
Let me know asap Thanks again!
Old 02-18-2007, 01:47 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Shift INDICATOR
What year is your Mountaineer?
Also, your text description of the indications is not clear. Is basically everything shifted to the right one place? Ie: R is displayed in park, N is displayed in reverse, D is displayed in neutral, 2 is displayed in drive, and 1 is displayed in 2nd gear?
If so, it sounds like the cable is just out of adjustment. Will need to know the model year to give specifics on how to adjust it.
-Rod
Old 02-18-2007, 02:55 PM
Re: Shift INDICATOR
God Should of said what year it was in the first place its a 98
and yes it just shifted 1 place to the right.
Old 02-18-2007, 10:58 PM
shorod's Avatar
SHO No Mo
Re: Shift INDICATOR
There is an adjustable thumb screw to adjust the transmission range indicator in the steering column. If you'd like a PDF version of the procedure, send me a Private Message with an e-mail address for you that can accept PDF attachments.
-Rod
