Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 02-18-2007, 01:07 PM
raff1ut raff1ut is offline
Need Help @002 Galant Starting Issues
2002 Galant 2.4L having issues:
Background:
Car originally from deep south ... relocated to intermountain west and after first week it's dead in the water. Although the move is probably unrelated to anything I suspected fuel problems being that between here and there (2100 miles) the likelyhood of getting bad gas is pretty good.
Went to crank car to warm before taking kids to school ... it ran about 5 minutes .. put it in reverse then poof. Fuel level was getting low .. maybe bad gas .. usually kept her above a quarter tank.
I put a small amount of fuel down the throttle and she runs briefly (lol til the fuel supply runs out).
Thus I concluded it was either the filter or the fuel pump so I replaced it ... seeing that its an all in one deal! Well I replaced the pump within the little unit. Is there a built in filter as well? I blew thru the hoses on the module lol ... everything appeared free! Gesh whatever happened to old fashioned filters n pumps??
Any Ideas??!!! Need help here is only mode of transportation!
Old 04-25-2007, 11:18 PM
sgt gonzo sgt gonzo is offline
Re: Need Help @002 Galant Starting Issues
This sounds like and IDLE CONTROL UNIT problem, it will start if you keep your foot on the gas pedal, but as soon as you take it of the pedal it will shut off. clean it or get it replaced.
