Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-18-2007, 11:14 AM
brokesilverado's Avatar
brokesilverado brokesilverado is offline
02 stang no drive
I have a 02 3.8L stang and the automatic tranny does not have drive any more it does have reverse it was working just fine. i was geting it out of a snow bank rocking it back and forth not hard and the drive just stopped no noise or anything. any info yah all would be greatly needed thank you.
Old 02-18-2007, 01:11 PM
2crunk's Avatar
2crunk 2crunk is offline
Re: 02 stang no drive
sounds like you need a new tranny, sorry.
Check out more pics and info on my Stang at: http://www.cardomain.com/profile/2crunk
Rest In Peace Hypsi87, you'll be missed.
Old 02-18-2007, 04:28 PM
351wStang's Avatar
351wStang 351wStang is offline
You probably burned it up. Normally when a trans gets too hot and starts slipping the first gears to go are the higher gears. The fix is a rebuild.
1969 Cougar
357w & TKO - 475hp
Old 02-27-2007, 11:41 AM
thanks for the info I will keep you all updated with the out come
Old 10-30-2009, 11:46 PM
needed new tranny the clutch packs were shot
Old 10-31-2009, 07:31 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
yeah, not a surprise...little known fact here...EVERY time tranny fluid be it synthetic or not, is over heated like when rocking it...it's life is cut in half...your car needs to be flushed every 30k...rock it once, now it needs to be changed in 15k....do it again...7500 miles....etc... remember, automatics are hydraulic creatures, they need thier fluid to work, and it has to be clean fluid.
