Old 02-18-2007, 09:45 AM
mjtr21 mjtr21 is offline
Engine Loses Power
I have a 1997 Jimmy SLE 4.3 4WD. Just recently when I am slowly accelerating the truck is fine. But when I push pedal down for a fast takeoff, it feels like the transmission is slipping or the engine is hesitating. Then i push the pedal down more and it is fine. When I get up to around 45-50 mph and try to pass another car the engine or transmision will start slipping or whatever. Sometimes the SERVICE ENGINE SOON light will flash. But I thought it was transmission problem. So I checked the transmission fluid yesterday and it was almost empty. I had it rebuilt by a transmission shop 2 years ago so it shouldnt be a transmission problem. I added fluid yesterday when it was low. My 4WD also doesn't work. I was leaning toward some kind of seal the goes bwtween transmission and transfer case. I read other threads about this happening to other people. I cant remember if it was an input or output and whether it was on the trans or transfer case. Please help. Thanks.
Old 02-18-2007, 10:16 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Engine Loses Power
Did adding fluid solve the transmission slipping problem?
A blinking check engine light points to a engine misfire or engine miss.
How is the tune up end or history.
Have you checked for stored codes?
Is the transfer case low or overfull on fluid?
On the 4W not working look around on here for 4W problem post.
What transfer case do you have?
AWD or the push buttons on dash?
MT
MT
Old 02-18-2007, 01:52 PM
yes adding fluid temporarily fixed my problem. i had changed spark plugs and wires in august. i dont know how to check transfer case fluid can you help me out. and i already found my problem with the 4WD. i will check codes today at AZ or Advance. i will post back no.
Old 02-18-2007, 03:30 PM
MT-2500's Avatar
AF - Advisor
The transfer case will have a drain plug on rear back bottom.
And almost half way up on back it will have a fill up plug.
And also a tag back thee to tell us what type transfer case.
Always use the right fluid.
MT
Old 02-18-2007, 07:24 PM
alright i will look for that drain plug on the back. i have the 3-button np233 transfer case i think. so if i open the drain plug the fluid should be level with the bottom of the plug right? thanks. i think i will find extra because my gues is my transmission fluid was leaking into it.
Old 02-18-2007, 07:30 PM
oh yeah i forgot i got SIX codes from my computer on the truck. P0101, P0147, P0300, P1406, and the other two didnt say any code numbers. 0101 was MAF sensor CKT, 0147 was O2 Sensor Bank 1 Sensor 3, 0300 was Random/Multiple Cylinder Misfire, and 1406 was EGR Pintle Position Circuit.
Old 02-19-2007, 09:07 AM
MT-2500's Avatar
AF - Advisor
With 6 codes that is the place to start.
Plus what is your tune up history?
But with that many codes clear codes and tell us what one comes back first.
MT
Old 02-19-2007, 09:18 AM
well i know that the misfire is a new one because lately i can feel it and the SERVICE ENGINE SOON light flashed a few times when i was trying to pass a car. but would the O2 sensor also cause loss of performance? I know that O2 sensor is bad because i had codes cleared a couple of months ago and it cmae back. so it said Bank 1 Sensor 3 is that the last sensor after the cat converter? i will see if i can clear them then.
Old 02-19-2007, 09:38 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
a bad O2 can make the engine run extremely rich and cause the missfiring that you are experiencing. i cant remember if 97 had 3 or 4 O2 sensors. take a look up under the truck and see how many you have.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 02-19-2007, 09:55 AM
MT-2500's Avatar
AF - Advisor
I think you need to get down to the basics here.
Like Good AC Delco plugs and fuel filter and air filter.
A miss fire will give a 02 sensor code or a bad 02 sensor could cause a miss fire.
Remember a code does not say replace the sensor it says check it out.
What code no were the 02 sensor codes?
Any after market stuff like a K&N filter.
How many miles on tune up?
MT
Old 02-19-2007, 12:12 PM
i already changed the plugs out with new AC DELCO plugs. And the air and fuel filters are both new. The O2 Sensor code was P0147 O2 Sensoe Heater Circuit Malfunction (Bank 1 Sensor 3) MIL Requested. Thats what the printout said.
Old 02-19-2007, 01:43 PM
MT-2500's Avatar
AF - Advisor
Keep a eye out for that miss fire blinking check engine light.
Clear codes and see what returns first.
And post back
The maf sensor or the egr valve can both mess things up.
Watch them real close.
The maf and egr can sometimes be cleaned.
On the 02 code check wiring and voltage on heater circuit.
Every thing has to work together.
MT
Old 02-20-2007, 12:11 PM
alright well its been about a week since the service engine light has flashed. so i dont think its misfiring anymore. how can i check voltage on O2 sensor?
Old 02-20-2007, 02:56 PM
MT-2500's Avatar
AF - Advisor
Which voltage do you want to check?
A good volt/ohm meter will read out voltages.
How about you other codes?
Has any of them come back or still there?
MT
Old 02-21-2007, 11:18 AM
is this sensor the last one after the cat converter? cause it said sensor 3. it also said heated so i think it's the last one. not too sure.
